Go Back   Rotary Car Club > Tech Discussion > RX-7 2nd Gen Specific (1986-92) > Archives
Archives All the stickies in one place
Old 03-04-2008, 03:22 PM   #1
Fuse List
Here's a list of the (interior) fuses and what they do. It's been a while since I've looked at it, but I think it's accurate. Just wanted to post it up before I forgot and I'll look over it later.
I think it's listed left to right, top to bottom, according to the diagram on the cover.
This is for a S4 N/A.
Heater
30A
L
Heater & A/C
B
Spare
10A
Spare
15A
Spare
20A
Defog
30A
W
Rear Window Defroster
B
Stop
20A
G/W
Stop Lights
Horn
W/R (B)
Hazard
10A
B/L
Turn & Hazard Flasher Lights
W/R (B)
Room
7.5A
L/R
Cargo Light
Courtesy Lights
Interior & Spot Light
Warning Buzzer or Chime
Door Lock Cylinder & Ignition Key Cylinder Lights
EGI & Emission Control System
Warning & Auto Clock System
Audio System
Power Antenna
W/R (B)
Antenna B
10A
LG
Power Door Lock System
Audio System
Power Antenna
W/R (B)
Illum.
15A
W/R
Anti Lock Brake System
Antenna IG
10A
B/G
Power Steering Control System
Audio System
Power Antenna
Rear Window Defrost
- > Starter Cut Relay -> Theft-Deterrent System
B/W (IG1)
Engine
15A
B/W
Fuel Pump
A/T Lock-Up
Charging System
Ignition System
B/W (IG1)
Meter
7.5A
B/Y
Over Drive System
Meters & Warning Lights
Back-Up Lights
Auto Adjusting Suspension Control System (A.A.S.)
Cooling Fan System
Heater & A/C
B/W (IG1)
Turn
15A
BR
Turn & Hazard Flasher Lights (via FC-02)
Power Wind
30A
B/R
Power Windows
Sun Roof
15A
G/O
Sliding Sunroof
Anti-Lock Brake System
B/R (IG2)
Empty
Rear Wiper
10A
LG/Y
Rear Wiper & Washer
Wiper
15A
L
Front Wiper & Washer
B/R (IG2)
Cooling Fan
15A [30A for Vert]
Y [B/Y]
Cooling Fan System
Heater & A/C
Convertible Top System
B/R (IG2)
Audio
20A
L/W
Audio System
Power Antenna
L (ACC)
Cigar
10A
L/B
Cigarette Lighter
Remote Control Mirror
Heater & A/C
L (ACC)
ABS
15A
W/R
W/R (B)
Empty
Empty
Old 03-04-2008, 04:10 PM   #2
classicauto
crash auto?fix auto
classicauto's Avatar
Good info!
Old 03-04-2008, 07:08 PM   #3
FC Specifications List
Here's a list I compiled using some RX-7 books on specifications of a new RX-7. These are mostly based on Yamaguchi's (1986) book.
Internal Project Code
P747
Steering
Rack and Pinion
- Steering Ratio = 20.3:1
-3.6 turns lock-to-lock
Power
- Steering Ratio = 15.2:1
- 2.7 turns lock-to-lock
- U-Turn Length = 9.8 m (32.2 ft)
Steering Wheel
Outer Diameter = 380 mm
Offset Downward = 5 mm (0.2 in)
Transmission
M Type (N/A)
- Clutch inside diameter = 150 mm (5.59 in)
- Clutch outside diameter = 225 mm (8.86 in)
- 1st = 3.475:1
- 2nd = 2.002:1
- 3rd = 1.366:1
- 4th = 1.000:1
- 5th = 0.711:1
- Reverse = 3.493:1
- Final Drive = 4.100:1
- 1st ---> 2nd Synchronizer Diameter = 65 mm (2.45 in)
R Type (Turbo)
- Clutch inside diameter = 160 (6.3 in)
- Clutch outside diameter = 240 mm (9.4 in)
- 1st = 3.483:1
- 2nd = 2.015:1
- 3rd = 1.391:1
- 4th = 1.000:1
- 5th = 0.762
- Reverse = 3.288:1
- Final Drive = 3.909:1 (4.100:1 optional)
- 1st ---> 2nd Synchronizer Diameter = 76 mm (2.99 in)
- 2nd ---> 3rd Synchronizer Cone Diameter = 65 mm (2.45 in)
Automatic (JATCO L4N71B) 4 Speed
- Torque Converter Ratio = 2.0:1
- 1st = 2.841:1
- 2nd = 1.541:1
- 3rd = 1.000:1
- 4th = 0.720:1
- Reverse = 2.400:1
Propeller Shaft
- N/A = 782 mm (30.8 in) long, 75 mm (2.95 in) thick
- Turbo = 774 mm (30.7 in) long, 74 mm (2.95) outside diam., 62.5 mm (2.46 in) inner diam.
- Automatic = 733 mm (28.9 in) long, 57 mm (2.24 in) thick
Body
Wheelbase = 2430 mm (95.7 in.) long
Front Track = 1450 mm (57.1 in) wide
Rear Track = 1440 mm (56.7 in) wide
Overall Length = 4290 mm (168.9 in.)
Overall Width = 1690 mm (66.5 in.)
Overall Height = 1265 mm (49.8 in.)
Curb Weight = 1190.5 kg (2625 lb) manual, 1225 kg (2695 lb) 2 seat auto, 1232 kg (2715 lb) auto 2 + 2
Weight Distribution
- Unladen = 51.2/48.8, front/rear
- 2 passengers w/ a full tank = 50.2/49.8, front/rear
Timeslips
N/A: 8.0 sec. 0-60, 16.1 1/4th mile, 128 mph top speed
Turbo: 6.7 sec. 0-60, 15.2 1/4th mile, 150+ mph top speed
Windshield
63.5 degree angle
Air Dam
Ramp Angle: 14 degrees
Hatch
Glass: 18.5 degrees to the horizontal
Cargo area lift-over height: 120 mm to 910 mm (35.8 in.)
Doors
Apertures: 1370 long x 970 mm high (53.9 x 38.2 in.)
Form Drag Coeff., Front Lift, Rear Lift, Frontal Area, Aerodynamic Drag Coeff.
Cd = 0.31 base (0.29 aero kit)
Clf = 0.08
Clr = 0.14 (0.07 aero kit)
A = ~2800 in^2
Cd x A = 0.56 (.524 aero kit)
Internal Engine Dimensions
Generating Radius (R) = 105 mm (4.13 in.)
Eccentricity (e) = 15 mm (.59 in.)
Trochoid Housing Width (b) = 80 mm (3.15 in.)
K Factor = 6.8
Displacement = 654 cc/chamber (1308 cc total)
Piston Engine Displacement Equivalency = 2616 cc (V = (3) (sq rt 3)(Reb))
Port Opening/Closing (N/A)
Primary Opens = 32 degrees ATDC
Secondary Opens = 32 degrees ATDC
Auxiliary Opens = 45 degrees ATDC
Primary Closes = 40 degrees ABDC
Secondary Closes = 30 degrees ABDC
Auxiliary Closes = 80 degrees ABDC
Exhaust Port Opening = 75 degrees BBDC
Exhaust Port Closing = 38 degrees ATDC
Port Opening/Closing (Turbo)
Primary/Secondary Opening = 32 degrees ATDC
Primary/Secondary Closing = 50 degrees ABDC
Exhaust Port Closing = 48 degrees ATDC
Intake Tracks Length
Primary = 434 mm (17.1 in.)
Secondary = 411 mm (16.2 in.)
Rotor / Seal / Spark Plug Info.
Compression Ratio = 9.4 N/A, 8.5 Turbo
Weight = 4.3 kg (9.4 lb)
Apex = 2 mm (0.08 in.), 3 piece
Side = 0.7 mm (.03 in)
Lead Plug = 18 mm (0.71 in) ahead of trochiod’s minor axis
Radiator
5.4 kg (11.9 lb)
Engine Dimensions
5.15 mm long x 5.35 mm wide x 640 mm high (20.3 x 21 x 25.2 in)
N/A = 153 kg (337 lb) with lubricant/coolant, without radiator and oil cooler
Turbo = 171 kg (377 lb) with turbo and intercooler
Turbo Info.
11 blade turbine = 64 mm (2.52 in)
Scroll’s smallest area = 6.00 sq, cm (0.93 sq. in) primary path, 9.48 sq. cm secondary (1.47 sq. in)
Distance between turbine shaft center and the center of area
- 59.4 mm (2.34 in) primary path, 60.4 mm (2.38 in) secondary
12 blade compressor diameter = 63 mm (2.48 in)
Max boost
- 2000-5000 rpm = 320 mm mercury (0.42 bar/6.2 psi)
- rpm >5000 rpm = 280 mm mercury (0.36 bar/5.4 psi)
Fuel cut = Boost > 400 mm
Max turbine speed = 110,000 rpm
Front Suspension
Wheel Travel = 180 mm (7.1 in); 80 mm up, 100 mm down
Caster Angle = 5 degrees
Shock’s Piston-Rod Size = 22 mm (0.87 in)
Spring Rate kg/mm (lb/in) = 1.9 (106) normal, 2.1 (118) sport
Spring Wire Diameter = 12.1 mm (0.48 in) normal, 11.9 (0.47) sport
Coil Diameter = 147.0 mm (5.79 in) normal/sport
A-arm Bushing Stiffness
- Front Bushing Axial Direction = 35 kg/mm
- Front Bushing Longitudinal Direction = 1250 kg/mm
- Rear Bushing Axial Direction = 50 kg/mm
- Rear Bushing Longitudinal = 450 kg/mm
Bushing
- Length = 50 mm (2.0 in)
- Inner diameter = 40 mm
- Outer diameter = 17 mm
Anti-Roll Bar Diameter = 22 mm normal, 24 mm sport
Rear Suspension
Spring Wire Diameter = 9.9 (0.39) normal, 10.1 (0.40) sport
Coil Diameter = 84.6 (3.33) normal, 84.4 (3.32) sport
Trailing-Arm Bushing Spring Rate
- Axial Direction = 250 kg/mm
- Longitudinal Direction = 1000 kg/mm
Anti-Roll Bar = 12 mm normal, 14 mm sport
Brakes
14 inch wheels (pressed steel)
- Cast Iron Single Piston Calipers with an 8 in vacuum servo
- Ventilated Front
- Solid Rear Disc
- Disc Diameters = 250 mm (9.8 in) front, 261 mm (10.3 in) rear
- Pad Areas = 86 sq cm (13.3 sq in) front, 64 sq cm (1.9 sq in) rear
- Caliper Weight = 4.3 kg (9.5 lb)
15/16 inch wheels (cast aluminum)
- Front Aluminum Four Piston Calipers / Single-Piston Floating Calipers (9 in vacuum servo)
- Caliper Weight = 3.2 kg (7.1 lb)
- Pad Areas = 94 sq cm (14.6 sq in) front, 64 sq cm (9.9 sq in) rear
- Disc Diameters = 276 mm (10.9 in) front, 273 mm (10.7 in) rear
Interior
- Fore-Aft Seat Adjustment = 200 mm (7.8 in)
- Tachometer Diameter = 112 mm (4.4 in)
- 150 mph Speedometer
- Luggage Space = 184 liters (6.5 cu ft) 2 seater, 104 liters (3.7 cu ft) 2 + 2 seats
- Front Head Room = 9.49 mm (37.2 in)
- Front Leg Room = 1109 mm (43.7 in)
- Front Shoulder Room = 1340 mm (52.8 in)
- Front Hip Room = 1380 mm (54.3 in)
- Rear Head Room = 839 mm (33.0 in)
- Couple Distance = 507 mm (20.0 in)
Heater
Fan Output (Elec.) = 200 watt/12 volt
Heater Output = 415 cu meters/hour (14,656 cu ft/hour)
Side Dash Vent Outputs = 30 cu meters/hour (1059 cu ft/hour)
Sunroof
Opening Size = 250 x 704 mm (9.8 x 27.7 in)
Audio
Grade 1 = No radio/tape deck
Grade 2 = AM/FM radio w/ electronic tuning
- Two 12 cm (4.7 in) dash speakers
- Two 16 cm (6.3 in) rear speakers
Grade 3 = AM/FM radio w/ twin diversity tuning reception antennas
- AM Stereo
- Mechanical Tape Deck
Grade 4 = AM/FM radio
- 9 band graphic equalizer
- Full Electronic Logic-Controller tape deck
References
Yamaguchi, Jack. (1986). Rx-7: the New Mazda Rx-7 and Mazda Rotary Engine Sports Cars. New York: St. Martin's Press.
Old 03-07-2008, 03:20 PM   #4
Roen
Evil Club Mod
Roen's Avatar
Additional Info
Steering
Power (RPM-Sensitive)
Steering Ratio - 17.4:1
Transmission
M Type (N/A, 87-92)
- 1st = 3.475:1
- 2nd = 2.002:1
- 3rd = 1.366:1
- 4th = 1.000:1
- 5th = 0.697:1
- Reverse = 3.493:1
- 1st ---> 2nd Synchronizer Diameter = 65 mm (2.45 in)M Type (N/A, 89-90 GTUs Only)
- 1st = 3.475:1
- 2nd = 2.002:1
- 3rd = 1.366:1
- 4th = 1.000:1
- 5th = 0.756:1
- Reverse = 3.493:1
- Final Drive = 4.300:1
R Type (Turbo, 89-91)
- 1st = 3.483:1
- 2nd = 2.015:1
- 3rd = 1.391:1
- 4th = 1.000:1
- 5th = 0.719
- Reverse = 3.288:1
R Type (Turbo, 91 Infini IV Only)
- 1st = 3.483:1
- 2nd = 2.015:1
- 3rd = 1.391:1
- 4th = 1.000:1
- 5th = 0.719
- Reverse = 3.288:1
Rotor / Seal / Spark Plug Info. (89-91)
Compression Ratio = 9.7 N/A, 9.0 Turbo
Brakes (89-92)
15 inch wheels (Standard Brakes)
- Ventilated Front
- Solid Rear Disc
- Disc Diameters = 276 mm (10.9 in) front, 261 mm (10.3 in) rear
- Pad Areas = 64 sq cm (1.9 sq in) rear
- 15/16 inch wheels
Old 03-07-2008, 04:21 PM   #5
You little theif . Yeah, I was getting to those later, but oh well.
I have a bunch more info that I'm going to post up.
Old 03-07-2008, 04:21 PM   #6
Stock Turbo Information (S4)
The stock turbo on an S4 features an 11-blade turbine measuring 64mm (2.52 in). The scroll's smallest area is 6.00 sq. cm (0.93 sq. in) primary path, and a 9.48 sq. cm (1.47 sq. in) secondary path. The distance between turbine shaft center and the center of area was 59.4 mm (2.34 in) for the primary path and 60.4 mm (2.38 in) for the secondary path. The compressor is a 12-blade design, with a 63 mm (2.48 in) diameter. The maximum turbine speed is 110,000 rpm.
The S4 FC featured a unique twin-scroll design that virtually eliminated turbo lag. At low speed, exhaust gas enters the turbo via the primary path. When the engine reaches 2500 rpm, the secondary path is opened.
Maximum Boost Levels
* 2000-5000 rpm: 320 mm mercury (0.42 bar/6.2 psi)
* 5000+ rpm: 280 mm mercury (0.36 bar/5.4 psi)
* Fuel Cut: 400+ mm boost
Edit: I guess I should of read Roen's post more carefully because this is on there too. Oh well...
Old 03-07-2008, 04:25 PM   #7
Stock Brake Information
14 Inch Wheels (Pressed Steel)
Front
* Caliper Type: Single piston cast iron, 8" vacuum servo
* Caliper Weight: 4.3 kg (9.5 lb)
* Disc Type: Ventilated
* Disc Diameter: 250 mm (9.8 in)
* Pad Area: 86 sq cm (13.3 sq in)
Rear
* Disc Type: Solid
* Disc Diameter: 261 mm (10.3 in)
* Pad Area: 64 sq cm (1.9 sq in)
15 and 16 Inch Wheels (Cast Aluminum)
Front
* Caliper Type: Four piston aluminum floating, 9" vacuum servo
* Caliper Weight: 3.2 kg (7.1 lb)
* Disc Diameter: 276 mm (10.9 in)
* Pad Area: 94 sq cm (14.6 sq in)
Rear
* Caliper Type: Single piston aluminum floating, 9" vacuum servo
* Disc Diameter: 273 mm (10.7 in)
* Pad Area: 64 sq cm (9.9 sq in)
Edit: I see the brake info is above... but I'm leaving this one up because it's prettier.
Old 04-04-2008, 02:01 AM   #8
Fun Visuals
P747 Prototype tails:
Wind Tunnel:
Old 03-07-2008, 04:26 PM   #9
Engine Bay Fuses
RETRACTOR: Headlight retractor motors
HEAD: Headlights
EGI INJ: Fuel injectors, ignition coils
EGI COMP: EFI system
ABS: ABS system
MAIN: Alternator, Interior fuse box
BTN: Interior fuse box
Old 03-07-2008, 04:27 PM   #10
Here's another way to read the interior fuses. There's less information overall, but a bit less confusing.
CIGAR: Cigarette lighter, A/C compressor, mirrors, clock, HVAC
AUDIO: Stereo, antenna relay
ENGINE: Main relay, fuel pump, alternator, torque converter lock-up
METER: Gauges, alternator warning, cooling fan control, cruise control, reverse lights, HVAC, warning lights, reminders, AAS, alarm, 4AT control
POWER ST: Power steering, rear defrost relay, antenna relay, starter cut relay
POWER WIND: Power windows, AAS actuators
TURN: Turn indicators, rear defrost switch
REAR WIPER: Rear wiper
WIPER: Front wipers
SOFT TOP: Convertible roof
COOLING FAN: Electric radiator fan
SUNROOF: Sunroof, AAS, ABS
Old 03-07-2008, 04:27 PM   #11
These come from the BTN fuse.
* HAZARD: Hazard lights
* ANTENNA: Antenna, power lock
* ROOM: Clock, stereo, interior lights, alarm, ECU
* STOP: Brake lights, horn
* ILLUM: Taillights, illumination, HVAC
* ABS: ABS system
Old 03-10-2008, 09:52 AM   #12
Here's some reasons why some of the fuses could blow/keep blowing.
Main Fuse (80A):
Battery hooked up backwards
Alternator cable terminal end touching anything grounded or chaffing anywhere
Engine Fuse (15A):
Main Relay/ Circuit Opening Relay/Fuel Pump
(Wayne88N/A from RX7Club.com)
1) Disconnect the plug from the back of the alt
2) Disconnect the circuit opening relay (pull the plug)
3) Insert fuse. If it blows, you have a wiring problem in the alt voltage reg/excitation circuit wiring (I'd look near the plug for chaffing against the water pump housing or front housing), the power circuit wiring for the fuel pump/circuit opening relay, or the main relay (or wiring going to it) is bad.
- Isolate those three down to find the gremlin...
- If it doesn't blow, reconnect the alt back plug and try again. If it blows, your alt volt reg is bad.
- Disconnect the fuel pump plug at the left aft strut tower...
- Reconnect the circuit opening relay. It if blows now, you've got a short in the wiring to the fuel pump connector, or the
circuit opening relay...If it doesn't blow...
- Reconnect the fuel pump connector. If it blows now, you probably have a bad fuel pump.
EGI Comp (30A):
- Feeds all the solenoids on the rack and the two solenoids on the ACV.
- Look for a broken wire around the acv solenoids or a bare wire at one of the solenoids on the left of the engine.]
- Check the wiring bundle in back of the alternator, I had (and someone else I know) had this same issue and it was due to the following problem; There's a metal clip, used to hold the bundle in place that is connected to the back of the alternator pivot bolt. After years of vibration, this metal clip wears at the insulation and causes a short. For me, no wires were visible, but the insulation was worn enough to cause a problem. Simply wrapped the wiring bundle in a couple layers of electrical tape and removed the metal clip.
