Old 01-07-2009, 02:53 PM   #1
13bpower
13bpower's Avatar
13bpower is on a distinguished road
Im haveing problem's, please help.
HI.I did a t2 s4 swap in a 87 base model rx7,like a monthe ago and my fuel pump went bad. But when i did my swap i used the n/a resistor and ran my car on the n/a fuel pump,and yesterday. I put on a t2 fuel pump and my car started right away lift it on for like 20min and reved it to like 4,000 rpm and it stalled,and now my car wont start. What can it be.Thank's for the help.
13bpower is offline   Reply With Quote
Old 01-07-2009, 06:06 PM   #2
13bpower
13bpower's Avatar
So nobdy know's...
Old 01-07-2009, 06:20 PM   #3
It could be many things.
Check for fuel at the rail
Check for spark
Check for compression
Do those things, and come back with the results.
Old 01-07-2009, 07:59 PM   #4
Check for spark
+1....
Check for full current to the pump, then check to make sure fuel fets to the filter, then check to make sure it goes PAST the filter and into the rails.....
Could be the pump, filter(s), injectors, vaccuum leak.....
You should go test everything you THINK could be wrong and when you're STUMPED and cannot think of a single thing...come back and ask....
right now you have no info for us so we can't give you any conclusive responses other than: find out.
Old 01-14-2009, 03:25 AM   #5
StarSpeedRacing
StarSpeedRacing
StarSpeedRacing is on a distinguished road
Make sure all your hoses are connected.
StarSpeedRacing
Parts Development & Discount Parts!
GB:FD Intercooler Kit
GB:Stainless Non Turbo Headers
Contact:
StarSpeedRacing@gmail.com
StarSpeedRacing is offline   Reply With Quote
Old 01-14-2009, 04:06 AM   #6
rotoriousrx7
rotoriousrx7 is on a distinguished road
make sure the relay on the driver side firewall behind the trailing coil, isnt bad it will not let the fuel pump kick on if its bad ran into this problem today with 88 vert/na
rotoriousrx7 is offline   Reply With Quote
