Go Back   Rotary Car Club > Vendors and Group Buys > All Vendors > Garfinkle's Motor Works
Garfinkle's Motor Works garfinklemw@gmail.com (TN) Custom products for 3rd Gen RX-7's
Old 01-06-2009, 10:25 PM   #1
Garfinkles Motor Works
New Fuel System setup - Feeler
Here are some pictures of a new fuel system setup that I have made.
Let me know what you think........
Also shows the same fittings on the aftermarket FPR
Old 01-06-2009, 11:03 PM   #2
Each new fitting has three o-rings to seal the part .The bracket is 3/8 steel ,the tube is a drilled through steel bar not thin wall tubing .The JIT fitting is brazed on ,not ferrule fit . The tube is brazed to the bracket as well .The fittings can be made with push on tubes for the stock rubber fuel lines . Chad may post picts of the fittings alone later .so you can see the o-ring set up .
Old 01-06-2009, 11:20 PM   #3
I had a chance to see these items in hand and they are top notch work!
I can't wait to get this bracket for my system!!
Thanks David for making unique custom parts!!
Old 01-06-2009, 11:24 PM   #4
fire85gslse
fire85gslse's Avatar
Pics are posted David.
And remember JIT fittings are cheaper than AN, dont require a special tool, and are made of stainless steel.
Also as seen the JIT fittings are on my fuel lines from the tank so a direct connection to the SS line.
Chad
Old 01-07-2009, 06:26 PM   #5
MOBEONER
MOBEONER's Avatar
MOBEONER is on a distinguished road
what is the price of these baby's.
MOBEONER is offline   Reply With Quote
Old 01-07-2009, 08:40 PM   #6
Brent
Sua Sponte
Brent's Avatar
This looks great David! Just waiting on the price!
Old 01-07-2009, 09:38 PM   #7
fire85gslse
This is a great setup and know exactly all the man hours that are involved in making it. I can tell you it will be worth the price he sets on it. I think I spent about $50 for each fuel Rail fitting. It is better that the AN fittings if you ask me.
A true work of art. If only I knew half of what he has forgotten.
Old 01-07-2009, 09:51 PM   #8
MOBEONER
MOBEONER's Avatar
that reminds me of when i was like 17-18 or so and i hung around JAYTECH`s shop when he operated his cnc machine and i would just sit there and look at the drill bits make a wooden mold for an intake manifold.it was just amazing how much work goes into just one part and we still complain about prices.lol
Old 07-13-2009, 05:40 AM   #9
fire85gslse
Bump for a sweet setup
Old 01-08-2009, 11:29 AM   #10
The brackets are wire edm cut with the holes so the machine has to be rethreaded four times each part .The tube starts is a solid peace of steel,drilled turned to size and groved for the two 0-rings . The bracket is countersink on eack side for the o-ring ,the third one, and to be brazed on the other .The allen holes are counterbored ,this allows the bolts to clear the oil injector with a filter .The Jit fitting has the threads cut off for good looks ,is drilled out to fit the tube .then all parts are brazed together .Then sandblasted and inspected .I have been using my set up for seven or eight years now .I suggest that you drop the fuel lines and braze JIT fittings on them for a complete job .Also I relocate the fuel filter at this time . Alot of money at one time but you should never need to do any more later .
Old 08-30-2010, 10:51 PM   #11
These fittings take longer to make then any other of the parts I sell .I have one set ready to sell as of today 8-30-10
Old 10-25-2010, 11:31 AM   #12
dguy
dguy is on a distinguished road
I'm interested in 3 fittings, do you happen to have any in stock? Thanks much.
dguy is offline   Reply With Quote
Old 10-28-2010, 12:56 AM   #13
I make a fitting for the end of both fuel rails nearest the fire wall and I cut and drill fittings to be brazed onto the fuel lines to and from the tank near the fire wall .What do you need ?
Old 02-04-2011, 01:28 PM   #14
FD3sAutobot
FD3sAutobot's Avatar
FD3sAutobot is on a distinguished road
I'm interested in a set. Sent you a pm.
FD3sAutobot is offline   Reply With Quote
Old 02-06-2011, 02:47 PM   #15
I have a set ready to send .
