Old 12-29-2008, 09:02 PM   #1
toyzzzz
toyzzzz's Avatar
toyzzzz is on a distinguished road
power steering issue?
Power steering starting making a little noise and sometimes doesn't work right away when starting the car. problems started after I changed the short hose between the pump and the fill tank. fluid acts like it needs to be bled (kinda bubbly and tries to overflow when turning wheel. I have now installed a different pump with the exact same issues as my previous pump. I have also tried jacking the front tires off the ground and with car running turned wheels several times with no effect.
Any ideas?
toyzzzz is offline   Reply With Quote
Old 12-29-2008, 09:35 PM   #2
Brent
Sua Sponte
Brent's Avatar
That's easy... pull all that stuff out and loop the lines. You don't need it Have you verified the pump is working or did you just switch one out with another one?
Old 12-30-2008, 04:07 PM   #3
You need to bleed the pump by turning lock to lock slowly several times. Sometimes it doesn't clear up for a while. It took forever to bleed the 626's system after changing everything but the rack.
Either keep at it, or return the pump and go manual. Chicks dig Popeye forearms
Old 12-31-2008, 04:50 AM   #4
need RX7
Clean S4 Nutswinger
need RX7's Avatar
. It's a piece of cake in the FC, can't be much worse in the FD.
Old 12-31-2008, 09:34 PM   #5
jkstill
jkstill is on a distinguished road
Street or track car? Sure.
Autox car? Forget it.
jkstill is offline   Reply With Quote
Old 01-08-2009, 06:31 PM   #6
albertomg
+1
I think the procedure is in the FSM if you'd like to review it further.
Old 01-14-2009, 08:53 AM   #7
cewrx7r1
The Judge
Obvious that it is caused by air in the lines because that is what you did to it and two pumps acting the same.
Old 01-15-2009, 09:29 AM   #8
REVIT93RX7
REVIT
REVIT93RX7 is on a distinguished road
Power Steering
Sounds like the system needs to be bled.
REVIT93RX7 is offline   Reply With Quote
Old 01-15-2009, 08:13 PM   #9
toyzzzz
toyzzzz's Avatar
After talking to a few local people, it seems as if it may be time for a new rack. possibly pulling in air. I've tried the bleeding methods offered of turning wheels lock to lock, and jacking in the air with motor off and turning lock to lock. Could the rack really be the issue?
Old 01-21-2009, 07:10 PM   #10
jkstill
If it is "pulling in air", then it should also be leaking fluid.
Have you found any leaks?
Check the hose you replaced. I replaced all my hoses, and the hoses to the plastic tank required extra care in clamping.
The problem was that the replacement hose (3/8" to the pump and 1/2" inlet IIRC) were not exact matches for the OEM hose.
I placed an extra clamp on each of these hoses, right next the the bead on the end of the pipe. That fixed it.
One way to check for a leak is to feel the bottom of the P/S fluid tank. If either of those hoses are leaking, the bottom of the tank will be wet.
P/S leaks look suspiciously like oil leaks, so you need to take some time to find out where it leaks.
Yes, my P/S used to leak.
Old 01-24-2009, 12:09 PM   #11
toyzzzz
toyzzzz's Avatar
Turns out the issue was definately the rack, Put the new remanufactured one in yesterday with new return hoses and everything appears to back to normal. Thanks for everyones input.
