Old 12-23-2008, 06:21 PM   #1
Rotary#10
Rotorhead
Rotary#10's Avatar
What does it mean when... fuel related question
What does it mean when you have no fuel pass the the engine bay fuel filter?... the filter only has about 6k miles on it. it shouldn't be bad.. i have fuel in the fuel lines at the fuel pump.. but no fuel on my plugs...its odd.. they smell of oil but not fuel.. car cranks ok... battery is fine.
its a 91 n/a FC...
Currently running:
90 N/A GTUs..
Running project car
89 N/A GTUs in Black #2
10/6/18
Old 12-23-2008, 06:21 PM   #2
just to make sure, you are saying you are getting now fuel past the filter?
Old 12-23-2008, 06:35 PM   #3
Rotary#10
Rotorhead
Rotary#10's Avatar
sorry it wasn't too clear
I am NOT getting any fuel at all to the engine. grr its iratating at times .. figuring whats wrong..
Currently running:
90 N/A GTUs..
Running project car
10/6/18
Old 12-23-2008, 06:41 PM   #4
pull the pump out and inspect the sock, tank, pump itself, etc. work from pump forward.
Old 12-23-2008, 06:54 PM   #5
wait....you have gas in the lines but not past the filter? If the filter on backwards?
Old 12-23-2008, 07:07 PM   #6
Rotary#10
Rotorhead
Rotary#10's Avatar
mm i did pull the filter off. and check and saw if it was clogged or not.. it could be possible i put it on backwards. i'll have to check and see... tomorrow..
Currently running:
90 N/A GTUs..
Running project car
10/6/18
Old 12-23-2008, 07:09 PM   #7
that' the only thing I can think of.....if you have fuel in the lines (pump is good) b ut not past the filter.....hope that's it.
Old 12-23-2008, 08:18 PM   #8
rx7 FC TII
rx7 FC TII's Avatar
rx7 FC TII is on a distinguished road
thats the only thing possible inless there is something stuck in the line.
rx7 FC TII is offline   Reply With Quote
Old 12-23-2008, 08:50 PM   #9
Is the fuel pump getting voltage?
The ENGINE fuse tends to blow sometimes, and this will prevent the fuel pump from turning on.
Old 12-26-2008, 01:10 PM   #10
Rotary#10
Rotorhead
Rotary#10's Avatar
UPDATE:
- Fuel filter is on the right way with 'OUT' facing toward the engine.
- the Engine fuse on the drivers side panel is ok
- there is continuity between a - c on the fuel pump connector, according to FSM pg.
F1-52 bottom of page under there fuel and exhaust section.
Currently running:
90 N/A GTUs..
Running project car
10/6/18
Old 12-26-2008, 03:02 PM   #11
Fuel pump working?
Pull the fuel line prior to the fuel filter...
Does it shoot fuel when you crank?
Old 12-28-2008, 08:29 PM   #12
Rotary#10
Rotorhead
Rotary#10's Avatar
Fuel pump working?
nah there is nothing coming out !! its werid ?!
Currently running:
90 N/A GTUs..
Running project car
10/6/18
Old 12-29-2008, 02:07 AM   #13
It's not weird...it's either dead, clogged or not getting enough voltage.
Old 01-01-2009, 05:30 PM   #14
Rotary#10
Rotorhead
Rotary#10's Avatar
EPIC FUEL PUMP FAILURE... !!! where is a good place to find one at a reasonable price ?
walbro kicks out too much fuel from what folks have tould me..
Currently running:
90 N/A GTUs..
Running project car
10/6/18
Old 01-02-2009, 12:10 AM   #15
Get a good, used stock one.
Check out the classifieds or post a wanted ad.
Can't beat the stock unit for relibility, even though yours died.
