Go Back   Rotary Car Club > Classifieds > 2nd Gen Classified > 2nd Gen RX-7 Parting Out
2nd Gen RX-7 Parting Out Parting Out Mazda RX-7 You must have over 4 parts to list your items here. No new parts allowed.
Old 12-09-2008, 05:26 PM   #1
87 t-66
87 t-66's Avatar
87 t-66 is on a distinguished road
Parting out 10th AE :(
unfortunately the shell of this car is too bad to fix so im taking a few things that i need and will be selling the rest. everything not listed is for sale. it also has a great condition black s4 interior. PM me if interested in anything.
so far here's what is sold.
turbo manifold
tps
window switch
window motor
mirror switch
injectors
waterpump/housing
gauge cluster
mirrors
omp
wing
throttle body
ftps
a/b pillars
ac lines
2 bracket/oil cooler line
turbo plumbing
87 T2
90 T2 'Vert
87 t-66 is offline   Reply With Quote
Old 12-09-2008, 06:05 PM   #2
How much would you want for all the components I would need to convert my automatic belts to manual?
A pillars, plastic behind door, belts, mounting bolts, all that crap.
PM me shipped to 37167
Old 12-09-2008, 06:06 PM   #3
87 t-66
87 t-66's Avatar
the a and b pillars are already sold and posted above. i am going to keep the seat belts for now.
87 T2
90 T2 'Vert
Old 12-09-2008, 06:07 PM   #4
Sorry I jumped the gun.
Thanks anyway! Free bump.
EDIT: what about the drivetrain: trans, DS, diff and axles?
Old 12-14-2008, 12:32 AM   #5
SoGlow7
SoGlow7's Avatar
SoGlow7 is on a distinguished road
clutch?
DD: 93' EG "Ferio" Sedan
Project: 88' TII *Rebuild* Since Spring of 07'
SoGlow7 is offline   Reply With Quote
Old 12-15-2008, 04:40 PM   #6
Still got the rear vertical carpet panels and trim for the hatch?
Willing to ship all that crap to Hawaii?
Old 12-16-2008, 09:41 PM   #7
shadowboym
shadowboym's Avatar
shadowboym is on a distinguished road
how about the ac/heater controls?
shadowboym is offline   Reply With Quote
Old 12-27-2008, 10:32 AM   #8
PortedRotorTuner
レーサー
PortedRotorTuner's Avatar
PortedRotorTuner is on a distinguished road
Were in Columbus.
Looking for TII motor, tranny, drive shaft, diff, and the two wiring harnesses to the engine bay. I'm looking into this for a buddy. Were going to convert
his vert into a turbo set up.
Thanks!
Thank God For Pistons! How else would we brake!
NASA Great Lakes Region
TTD #53 Rx7
PortedRotorTuner is offline   Reply With Quote
Old 01-06-2009, 05:56 PM   #9
87 t-66
87 t-66's Avatar
please PM me if interested in anything.
here's whats left:
s4 t2 engine harness (a few cut wires but all connectors appear to be in tact - $45
jspec s4 t2 ecu - $25
s4 t2 battery/starter harness - $50
s4 t2 rear harness - $50
jspec top mount - $25
stock rad hoses - $8
s4 t2 fuel injector resistor pack - $15
variable resistor - $8
stock pulleys - $3 each
radiator brackets (look new) - $25
cold start bottle - $15
n326 atmospheric pressure sensor - $8
rear wiper reservoir/motor - $8
s4 t2 jdm lim - $25
s4 t2 jdm uim - $25
s4 t2 usdm lim - $25
s4 t2 usdm uim - $25
s4 t2 turbo to exhaust mani gasket - $8
10ae steering wheel - $25
s4 t2 cruise control computer - $10
s4 t2 power steering computer - $10
s4 t2 fuel sending unit - $30
tilt steering column - $25
long oil cooler line - $15
lock set (ignition, hatch, door handles) - $75
working hatch struts $30
usdm top mount - $25
stock t2 intake elbow - $10
stock t2 intake temp sensor - $10
clock spring/turn signal canceler - $20
s4 front control arms (pair) - $35
s4 t2 stationary gears - $5/each
coupe window glass - $25/side
t2 oil filler neck - $10
ecu kick plate cover - $8
strut tower covers - $8/pair
security light (next to mirror switch)- $4
cruise control switch - $5
s5 rear mouldings w/ marker lights and screws - $15
headlight assemblies (i have 6 i believe) - $20 each
ebrake cover - $5
ebrake assembly - $10
s5 stock fuel/temp gauge - $10
s4 t2 abs computer & harness - $15
s4 or s5 gauge cluster harness - $10 each
bin wiring w/ bulbs - $5
main relay - $5
black s4 rear speaker covers (hairline crack in each) - $10
black headliner w/ sunroof panel - $40
black carpet set - $180
black bins - $50
87 T2
90 T2 'Vert
Old 01-10-2009, 12:58 PM   #10
Rotorhead37
Rotorhead37's Avatar
Rotorhead37 is on a distinguished road
How about the two front calipers? I need a set for a 88 TII. PM me with a price if you still have them. They are for my sons car, he is in Afghanistan right now. The car has been sitting and the fronts have locked up. Probably needs rotors as well, what kind of condition are your in?
Rotorhead37 is offline   Reply With Quote
Old 02-03-2009, 06:03 PM   #11
87 t-66
87 t-66's Avatar
heres a current list of parts for sale. please PM me if you're interested in anything. im not getting email notifications of replys for some reason.
new fc thermoswitch/coolant sensor w/ plug - $20
flywheel socket (1" drive) - $10
omp vacuum spider - $15
n319 jspec s4 t2 ecu - $20
(2) s5 round injector plugs - $8
s5 AFM plug - $7
PCV (purge control valve) - $7
OMP vacuum spider - $7
s4 t2 n326 atmospheric pressure sensor - $8
s5 fuel pump resistor/relay - $15
air pump - $10
t2 sway bars - $40/both, $25 each
yellow hks intake filter - $40
10th ae badge - $25
s4 turn signals - $10
s4 t2 fuel pump sending unit - $25
s4 t2 jdm lim - $25
s4 t2 jdm uim - $20
s4 t2 usdm lim - $20
turbo block to manifold gasket - $20
s4 t2 jdm bac - $15
strut top covers - $8
FD intake temp sensor (neeeded to run Apexi PowerFC in a FC) - $15
s5 NA engine harness (great shape, missing rats nest plugs, have a spare harness with those connectors that i can include) - $50
s5 TPS - $35
s4 t2 waterpump housing - $35
s4 t2 thermostat neck - $15
plastic piece between coolant filler neck and thermostat neck (w/ overflow nipple & cap) - $25
lock set (doors,hatch,ignition) - $85
stock intercooler couplers - $5/each
s4 front control arms (pair) - $40
passenger window glass - $30
s5 waterpump - $10
s5 rear mouldings w/ marker lights and screws - $18
ebrake cover - $5
s5 t2 power steering computer - $8
s4 or s5 gauge cluster harness - $15 each
bin wiring w/ bulbs - $8
main relay - $8
headlight assemblies (each) $25
motor mounts and brackets $40
black headliner w/ sunroof panel - $30
87 T2
90 T2 'Vert
Old 09-17-2009, 06:57 PM   #12
shahee1
shahee1 is on a distinguished road
You still have the amber windshield??? T2 Engine harness???
shahee1 is offline   Reply With Quote
