Go Back   Rotary Car Club > Vendors and Group Buys > All Vendors > Atkins Rotary
Atkins Rotary www.atkinsrotary.com (WA) Rotary engine and engine part supplier
Old 12-09-2008, 03:00 PM   #1
Intake manifold for 13B 4 port? (TII irons)
I see you have intake manifolds for the old 4 port 13B, the 12a and the 6port cars. Any chance the 78 and prior manifold will work on a 13B TII engine? Obviously not for turbo reasons.
Old 12-09-2008, 04:07 PM   #2
Jeff20B
Jeff20B's Avatar
Won't work. Just swap the manifold with Atkins.
Old 12-09-2008, 05:30 PM   #3
i don't quite get what you mean.
Old 12-09-2008, 05:51 PM   #4
do you make one for the turbo II engine then?
Old 12-10-2008, 12:53 PM   #5
Atkins Dan
Premium Vendor
Atkins Dan's Avatar
Atkins Dan is on a distinguished road
What set up are you trying to run???
Dan
82 SuperCharged rx-7 {my toy not the daily driver anymore now under restoration}
88 B2200 rotary powered with a 7inch Camden SuperCharger !RIP! Jan/4/2007
2001 626 5-speed 80k on the clock all stock {Truck replacement}
2005 MAZDA6 V6 WAGON now that is a pimping ride all stock for the moment.. Paid off
WWW.AtkinsRotary.com
Atkins Dan is offline   Reply With Quote
Old 12-10-2008, 01:00 PM   #6
Dan
13BT (1987 block) but in NA form. Running a Megasquirt. Looking for an alternative intake manifold other than the turbo II one.
Old 12-10-2008, 02:39 PM   #7
Atkins Dan
Premium Vendor
Atkins Dan's Avatar
you mean like these????
http://www.atkinsrotary.com/store/home.php?cat=589
I also have a wrap over manifold that will put the weber or throttle body behind the alternator..
Dan
Old 12-10-2008, 02:43 PM   #8
yea one of these (either the straight out side draft (lakewood style) or the wrap over). What ever you have that will work on the TII engine.
Old 12-18-2008, 02:00 PM   #9
Atkins Dan
Premium Vendor
Atkins Dan's Avatar
ok the straight out manifold is 250.00 the wrap over is 275.00... shipping Ground with in the USA is about 14.00
Dan
Old 12-19-2008, 01:14 PM   #10
Dan
great, ill give ya'll a ring after xmas
Old 12-19-2008, 01:57 PM   #11
Final question though
Which would suit my needs better, the wrap over or the side-draft?
Engine is to be as follows:
12a distributor w/ Megasquirt for fuel
9.4 or 9.7 CR rotors
Turbo II irons
Large streetport (or 1/2 bridge) or possible full bridge.
i know there is jump between full bridge and 1/2 bridge in methodology but thanks to living at 6500 ft (and higher) i need every bit of what i can get power wise. The motor will eventually find itself in my hillclimb / rallycross car, so i am looking for mid to high end power.
