Old 12-08-2008, 05:48 PM   #1
FS: S5 Engine parts: rotors, iron side housings, ecentric shaft, front cover, etc.
Ok, so I tore down my engine that had 141,000 on the clock. It did NOT loose an apex seal! My motor instead had a coolant seal leak in the front housing, so I ended up getting another motor to put in my car.
I have all the core parts available, but some of the stuff like the rotor housings, and the front side housing are trashed.
I am not looking to make mega bucks on this stuff, and if I do not sell anything, I will just use the pieces to practice porting, make a dummy engine block for fabrication, etc.
List of usable parts:
Middle Iron Plate
S5 Rear Iron Plate
Front cover
Ecentric Shaft
Both Hi Compression S5 rotors
Front Conterweight
Stock N/A flywheel
Front Stationary Gear
Rear Stationary Gear
The parts may not be brand new, but they seem too be in fair shape, and quite usable. Shoot me an offer, and I will be glad to work something out.
Pictures of rotors:
Old 12-08-2008, 05:59 PM   #2
pm'ed
Old 12-08-2008, 06:27 PM   #3
replied!
Old 01-04-2009, 04:35 PM   #4
Pictures of rotors added.
PM me about anything else you'd like to take a look at, I promise I will respond as quickly as possible, sorry for the last time, low impedence.
PS: The rotors only recieved a light wire wheel cleaning, they feel really smooth to the touch, and except for the bearings showing wear after 141K, these seem to be in great working order! The colored spots are because my bench grinder wasnt bolted down, so it was difficult to clean them up 100%.
Old 01-16-2009, 01:43 AM   #5
jamespond24
jamespond24 is on a distinguished road
Got the housing? If so please post pics.
jamespond24 is offline   Reply With Quote
Old 01-26-2009, 01:40 AM   #6
Yes, you should really PM me if you want a quick response dude. Because the board is currently a bit slow going, I havent checked it till now!
