Go Back   Rotary Car Club > Vendors and Group Buys > All Vendors > Rotary Extreme
Rotary Extreme www.rotaryextreme.com (CA) Rotary Extreme is back, still offering the same high quality products
Old 12-01-2008, 12:48 PM   #1
rotaryextreme
i like spinners
rotaryextreme's Avatar
rotaryextreme is on a distinguished road
Group Buy
Starting Janurary, details will be givin then.
Group buy on
FD engine Dampers
FD Trailing arms and toelinks
In March I will have a group buy on the FD v-mount after the revision of the brackets and ducting is complete. This kit is being revised due to driver feedback from drift drivers and also it is being updated to support race-spec time attack cars.
I am working with Falken signed driver Calvin Wan and refreshing his FD with the new set-up. The new set-up will be robust and will not interfere with the tow hooks which are used on drift and time attck cars. The new kit will include ducting. The kit will be a complete bolt on affair and will still allow you to keep A/C with the exception of the A/C lines which still require minor modification if you wish to keep your A/C.
Thank you,
Ben-Rotary Extreme
The ingenious and decidedly weird Wankel rotary engine works by using internal combustion to bounce a fat metal triangle around inside a hollow metal kidney bean, which hula-hoops around a central shaft to generate power.--- Jalopnik www.rotaryextreme.com, after more then a 2 year break, Rotary Extreme Re-opens 9/11/08.
rotaryextreme is offline   Reply With Quote
Old 02-02-2009, 03:25 PM   #2
rotaryextreme
i like spinners
Hello,
Does anybody have any request on group buys or any questions about what's up and comming?
Ben
Old 02-02-2009, 04:02 PM   #3
HDP
HDP is on a distinguished road
I need toelinks and pillow balls...
HDP is offline   Reply With Quote
Old 02-02-2009, 06:50 PM   #4
rotaryextreme
i like spinners
HDP, pm sent
Old 02-04-2009, 05:02 PM   #5
blackr1
blackr1 is on a distinguished road
anything about the old RE Headlights?
blackr1 is offline   Reply With Quote
Old 02-05-2009, 11:59 PM   #6
prrex4ever
prrex4ever's Avatar
How about the Feed style side skirts. Can't find them anywhere in carbon fiber except the authentic ones and they are $$$$$$.
Old 02-06-2009, 03:08 AM   #7
rotaryextreme
i like spinners
I'm a little late on the aero kit section but it is going to re-open. As for the lights, I am getting everything to make them again but I'm also looking into the lexan cover to see if it is cost effective to have it shaped with the same contour as the pop-up cover. Otherwise it will remain a flat piece.
Ben
Old 02-06-2009, 09:03 AM   #8
blackr1
that would be really cool if it followed the same lines.
Old 04-06-2009, 09:12 AM   #9
RIZZXX7
DIGG7ER
RIZZXX7's Avatar
RIZZXX7 is on a distinguished road
oil cooler setup for fd?
EXCELLENCE IS NEVER AN ACCIDENT, IT IS ALWAYS THE RESULT OF HIGH INTENTION, SINCERE EFFORT, INTELLIGENT DIRECTION, SKILLFUL EXECUTION AND THE VISION TO SEE OBSTACLES AS OPPORTUNITY...
RIZZXX7 is offline   Reply With Quote
Old 04-06-2009, 11:49 AM   #10
rotaryextreme
i like spinners
RIZZXX7 pm'd
Old 04-07-2009, 12:50 AM   #11
imstillonjava
imstillonjava is on a distinguished road
how goes things with the vmount?
imstillonjava is offline   Reply With Quote
Old 04-07-2009, 01:45 AM   #12
rotaryextreme
i like spinners
half way there on the new design...almost done
Old 04-15-2009, 02:13 PM   #13
blackr1
how about the headlights?
Old 04-16-2009, 12:18 PM   #14
rotaryextreme
i like spinners
I have located everything to re-make it. But I need to put one togther on my own first before I re-release it to make sure it has everything. Also it will be the same as before. You will have to pr-heat the lexan to get it to form to the housing, That way it matches the lines. This is something that I am thinking of doing so that the customers do not have to.
