Old 11-29-2008, 09:32 PM   #1
-xlr8planet-
-xlr8planet-'s Avatar
You can use a Y iron in a R5 engine...
As long as its a middle iron
what you CANNOT mix, its front and rear irons
New apex seal vs. used apex seal. The triangular piece is new on both
YES, you can use a middle Y irong in a R5 engine.
Porrrrrrrrrrrting
Old 11-30-2008, 10:22 AM   #2
not exactly familiar with "R5". What is that referring to exactly
Old 11-30-2008, 11:12 AM   #3
-xlr8planet-
R5 is the designation for the 79/80 12A irons.
Y is the designation for the 81/85 irons.
R5 engines use 18 tension bolts
Y engines only use 17
There are small changes depending on what market the engine was going to.
Old 12-09-2008, 01:53 PM   #4
Jeff20B
Jeff20B's Avatar
I have various R5 rear plates with 19,18 and 17 tension bolts. It depends on the year they were made. Most nitrided ones lack an oil pressure hole so it takes a steady hand and lots of patience to drill and cut threads.
Old 12-09-2008, 01:56 PM   #5
am i looking at it wrong, or is the tension bolt going to be exposed in the water jacket?
Old 12-09-2008, 02:09 PM   #6
Jeff20B
Jeff20B's Avatar
A Y intermediate can't be used with all 19 tension bolts because the casting apparently won't allow it.
Old 12-10-2008, 06:15 AM   #7
-xlr8planet-
I only have 18 tension bolts on my R5...
see
and I placed a black X where the tension bolt that the Y iron does not support should be.
Old 12-10-2008, 06:18 AM   #8
-xlr8planet-
On the R5 middle iron, (blue mark) you have a tension bolt hole.
On the Y iron (red mark) you dont, its all water.
On the rear R5 iron, you DONT have the tension bolt hole
So I guess it doesnt matter.
