Go Back   Rotary Car Club > Vendors and Group Buys > All Vendors > IR Performance
IR Performance www.myspace.com/rotaryexperimentseven (NJ) We work on any rotary cars
Old 11-28-2008, 07:03 PM   #1
IR Performance
IRP Polyurethane Motor Mounts
These will be polyurethane and incorporate the stock aluminum and steel arms (or you can use two of either) They will be the same height as the stock mounts so they won't raise the motor and cause fitment issues like some other mounts. There will be the main mount as well as a smaller disk to be placed under the subframe. There will be a metal insert through the main mount that the bolt will go through. This will not only prevent the bolt from wearing out the hole over time, but will also prevent over-tightening and compression on the mounts. They will be available in at least 2 different levels of firmness. I don't think anyone else on the market offers this. Grade 8 hardware will be used. I can make them in black or the orange shown. Price is yet to be set but will be close with the other mounts on the market. Here is a test fitting picture.
www.irperformance.com
irperformance@live.com
732-662-1794
Old 12-08-2008, 10:39 PM   #2
IR Performance
I have both 80A and 60A hardness mounts done. The 80A being stuffer, but should still transmit less vibration that others on the market.
732-662-1794
Old 01-11-2009, 12:28 PM   #3
IR Performance
I have decided to make the mounts using 2 steel arms from now on. Although the aluminum arms work fine, I think the steel look nicer.
732-662-1794
Old 01-12-2009, 07:28 AM   #4
proz07
Needing a new tow rig.
proz07's Avatar
do these really mount to the mount arms? im probably gonna be in the market for some replacements this year and all the ones ilook at look like its just sandwiched in between the arm and the frame with the bolt holding it together. maybe you can explain or show me if im wrong?
z
Old 01-12-2009, 04:31 PM   #5
IR Performance
The urethane pucks are sandwiched between the motor mount arms and subframe. They have a steel tube insert in the center which makes it a tight fit, but bolt can be put through by hand. There is no reason to hard mount the pucks to the arms. It will only transmit more vibration. Also, it would make it nearly impossible to change motor mounts with the engine in the car without dropping the subframe.
732-662-1794
Old 01-12-2009, 11:36 PM   #6
proz07
proz07's Avatar
ok i see. what kind of price are we talking for these?
z
Old 01-13-2009, 04:00 PM   #7
IR Performance
$250 providing you give me a set of core arms
732-662-1794
Old 01-14-2009, 02:49 AM   #8
proz07
proz07's Avatar
ok fair enough but what do you do that costs twice as much as say....banzia racing urethane engine mounts? Being i dont have to send them any arms.
z
Old 01-14-2009, 11:27 AM   #9
IR Performance
Unless there was a sudden price change, I believe my mounts are similarly priced. Where are you finding a pair of motor mounts for $125?
732-662-1794
Old 01-14-2009, 11:15 PM   #10
proz07
proz07's Avatar
Banzia-racing.com mind you the price to send them in is $250 but they also will ship you the mounts to do it yourself for $130. Will you have an option like this?
z
Old 01-15-2009, 12:30 PM   #11
IR Performance
I only plan to sell complete mounts. I also guarantee that my mounts will cause less vibration than others. Also, no one else offers mounts in various hardness options to my knowledge.
732-662-1794
Old 01-15-2009, 10:27 PM   #12
proz07
proz07's Avatar
cool sounds good thanks for all the info.
z
Old 01-28-2009, 12:10 PM   #13
IR Performance
I mean If you really wanted I could cut you a set of the pucks and you could put them together. I just feel better about assembling the entire thing.
732-662-1794
Old 02-08-2009, 11:21 AM   #14
IR Performance
I'm going to put the mounts on sale this week. Stay tuned.
732-662-1794
Old 02-16-2009, 11:40 AM   #15
IR Performance
I think I'm going to run a special on these. $200 a pair. What do you guys think?
732-662-1794
