Old 11-26-2008, 01:18 PM   #1
Question regarding bleeding brakes
Put in a new master cylinder last night (thanks to spooledup) but i did not have anything to bench bleed it. So we had to put it in as it was. (really really didn't want to have to do it that way...).
Anywho, i go around and start bleeding. The rears didnt have much pressure at all, and by the time i got the the driver's front, i had very good pressure. Granted each time i went to a new corner, there was a fair amount of air coming out for the first couple bleeds.
All and all the car does not stop all that well. I have good pedal feel, but the brakes aren't really accomplishing much. It stops, but nothing in the realm of quick.
So is it possible that since there was sooo much air in the master cylinder, that even after the bleeding i did, there is still air in the system? I might help explain why the rears where not getting much pressure going on. (more just trickled out).
So should i do another round of bleeding?
Old 11-26-2008, 01:45 PM   #2
josh18_2k
just keep at it...
i highly recommend speed bleeders. they work amazingly well. after i changed my front calipers it seriously took about 2 minutes to bleed my brakes, by myself.
theyre like $13 a pair. totally worth it. Russel makes them, so you can get em at autozone or whatever.
Front- SB8100 M8 X 1.0 1.28" (35.54mm)
Rear- SB7100 M7 X 1.0 1.38" (35.15mm)
oh, and i didnt bench bleed my master either. just pour and pump. i would keep going with a caliper until you run a whole master full of fluid through it with no air bubbles. sometimes it'll take like 10 pumps of nice solid fluid, before a bubble will appear.
Old 11-26-2008, 07:01 PM   #3
yeti
yeti is on a distinguished road
Originally Posted by josh18_2k View Post
just keep at it...
Well there is my problem.. I guess when I get around to my brakes again I'll buy some of these. Does brand matter in speedbleeders?
1989 vert, RB header and presilencer (looking for a catback), SAFC-II, custom fiberglass speakerbox, 130 amp alternator sweetness.
Parts Interchangeability List
yeti is offline   Reply With Quote
Old 11-26-2008, 07:21 PM   #4
just keep at it...
Autozone sells three kinds, only one is metric and it sure as hell doesnt fit. Summit racing does sell the Russell ones. Has the same part number for front and rear. They come in pairs and are about 10 dollars.
The SB8100 and SB1700 i could not manage to cross reference with anything.
Old 11-26-2008, 10:15 PM   #5
yeti
http://www.speedbleeder.com/automobi...ions.htm#Mazda
I guess these are not russell brand.. but they are 7(steel) or 15(stainless) for I guess one..
Old 11-26-2008, 10:53 PM   #6
i'm with the crew...keep at it.
Old 11-26-2008, 11:09 PM   #7
firzen
I have/had the same issue. I just keep going, give up for a day, then come back later. My brakes still don't feel as firm as I'd like but they still work; the shop that gave me the annual State Inspection even OK'd it.
I will probably bleed them again come springtime. Hopefully the fluid would have absorbed/dissolved some of the bubbles. Might be wishful thinking on my part but I'm not keen on bleeding the brakes when it's below 30°F in the garage.
Good luck.
Old 11-27-2008, 01:04 AM   #8
damn, below 30?? how long till the car warms up?
Old 11-27-2008, 01:38 AM   #9
firzen
Never really timed it but around 5-10 minutes, I'd say. I spend the time to pump the pedals a bit, fiddle with the electrics, charge the battery, and check for gremlins.
I try not to drive in the winter time as they salt the roads like Romans desolating Carthage.
Old 11-27-2008, 01:51 AM   #10
Yea Ohio was like that with the salt. When you have several salt mines within miles of your town, salt has less value than water.
Tomorrow i think im going to give it another go and see if it improves.
Old 11-28-2008, 01:01 PM   #11
The rears seems pretty sorted. Good flow coming out, steady, etc.
The fronts seems funky. As soon as you open the fronts it shoots out with some serious velocity but not much flow. I think i STILL need to rebleed the fronts til i get an actual flow out of them. Car still isnt the best stopping wise so i know the issue isnt resolved.
Old 11-28-2008, 04:32 PM   #12
josh18_2k
oh i got my bleeders at Baxter. i assumed autozone had them.
regardless, you can just get em at summit. same price, except you gotta pay shipping.
totally worth it!
everyone buy them lol
the sizes i posted are correct. i just wrote them down, took them into baxters, and they guy grabbed them for me from behind the counter.
LI- we mean it when we say keep at it. back when i bled my brakes the old fashioned way, it took me like half an hour to get one caliper done. and if you ever let the fluid level drop too low, the clock resets. its a bitch.
so to make sure the lines are clear, run at least a full reservoir, if not two, through each caliper with zero bubbles.
Old 11-28-2008, 04:43 PM   #13
seems like that is the goal for now. Need to buy more fluid. I plan on running at least the whole master worth of fluid through each front.
Old 11-28-2008, 05:26 PM   #14
Fidelity101
Reliable Source
Fidelity101's Avatar
just keep an eye out on your fluid level, I've bleed mine before and kept going and accidentally went below the minimum line so it sucked more air back in
had to do it all over again heh.
My Rx-7 Vids
Old 12-20-2008, 05:14 AM   #15
StarSpeedRacing
StarSpeedRacing
StarSpeedRacing is on a distinguished road
Start bleeding from passenger rear then passenger front.
Drivers front then drivers rear. Thats the order you bleed brakes.
If you have good pedal feel did you ever think it could probably be your pads?
Low quality pads or auto part store brands are cheap but sometimes better than getting them done.
What type of pads are you using?
StarSpeedRacing
Parts Development & Discount Parts!
GB:FD Intercooler Kit
GB:Stainless Non Turbo Headers
Contact:
StarSpeedRacing@gmail.com
StarSpeedRacing is offline   Reply With Quote
