Go Back   Rotary Car Club > REGIONAL FORUM > West RCC forum > California
Old 11-23-2008, 12:58 PM   #1
retaliate1st
retaliate1st's Avatar
retaliate1st is on a distinguished road
Arrow So. Cal Steve Kan Tune Day Guaging Interest
This is copied from Jesuscookies' thread on the evil forum:
I am going to be setting up another Steve Kan Tune day in So. Cal, and would like to gauge interest.
Currently I am looking at sometime in January, and was thinking the weekend of the 24th or the 31st.
Post up if you are intereted. We need at least 5 people for him to come out, but can usually squeeze in 9 or 10 or 2 days.
Based on your input, I will nail down an exact date, and start collecting deposits on a first come first serve basis.
__________________________________________________ _______________
We already have four people signed up / we need at least one more to lock in the date. The tuning session will be held at J & G auto in La Crescenta.
Pricing:
Prices for the tune are directly from the Steve Kan sub forum:
$350 - Stock turbo up to 12psi of boost (pump gas only) 1 map
$400 - aftermarket turbo up to 16psi of boost (pump gas only) 1 map
$450 - aftermarket turbo from 16psi - 25psi of boost (race gas and/or auxiliary injection only) 1 map
$600 - aftermarket turbo up to 25psi of boost (pump gas and race gas tune) 2 maps
Here is the estimated time frame allocated for each type of tuning.
1) stock turbo - 45 mins - 1.5 hrs
2) aftermarket turbo (pump gas) 1hr - 2.5 hrs
3) aftermarket turbo (race gas and/or auxiliary injection) 2 - 4hrs
4) aftermarket turbo (2 maps) 3-6 hrs
Dyno time pricing is as follows.
1) +150
2) +200
3) +250
4) +300
If for ANY reason you have to come off and get back on the dyno there will be an additional $50 added onto the dyno fee. So be prepared, and have everything squared away BEFORE you get strapped down.
Use of the shop's wideband is available for $15. Absolutely no race gas!
Be prepared! REAR DIFFUSERS need to be removed before it is your turn to tune. If you want the shop to do it for you, The charge will be $40.
As I said, we already have four people. Deposits will not be taken until we have at least 5 people and date is locked in.
("other forum" names)
1. retaliate1st
2. Jesuscookies
3. Maximum
4. Re-mamamia
5.
6.
7.
8.
9.
10
retaliate1st is offline   Reply With Quote
