Old 11-22-2008, 08:32 PM   #1
P71
P71's Avatar
Cool So I weighed my FB tonight...
In the middle of a *ahem* "sporting drive" I happened upon an easy way to hit the truckstop on I-5 by my house, so I figured what the hell. Stock 1983 RX-7 GSL with power windows/mirrors, cruise, A/C, glass sunroof, and full emissions intact with a full tank of fuel (minus about a gallon from the station to the scale) and the spare, jack, etc still inside.
2,650 Lbs.
Considering I weigh about 235 at the moment that's not bad! So 2,415 for an all-stock, fully-loaded FB, with a full tank. Figure I run it at about 1/3 tank in the autocross, plus no roof/spare/jack/spare oil/etc. Gas weighs 6.15Lbs/gallon, so take out 60Lbs of gas, and maybe 25Lbs for the roof/spare/etc and it's maybe 2,565Lbs when I autocross.
I'll re-weigh it as I take stuff out (A/C, emissions, exhaust, interior stuffs). I'd like to get it around 215Lbs out to bring it to 2,200 without me and under 2,500 with me. So figure the A/C stuff weighs quite a bit, same with the smog pump and the factory exhaust manifold. Also relocating the battery and replacing it with a lighter one, also going to a lighter interior insulation and seats. Should be doable, right?
Michael Pinto
Read my Rx-7 Build Thread!
Vote for the ROTM!
P71 is offline   Reply With Quote
Old 11-22-2008, 10:27 PM   #2
josh18_2k
those are incriments of 50, so pretend its 2601 ;-)
Old 11-22-2008, 10:32 PM   #3
need RX7
Clean S4 Nutswinger
need RX7's Avatar
Damn, that is really light.
Kind of off-topic, but can you go to any truckstop and get a car weighed or do you know someone there or something?
Old 11-22-2008, 10:39 PM   #4
Kentetsu
Kentetsu's Avatar
The emissions parts and AC do weigh a ton. I couldn't believe how heavy that shit was when I pulled it all off. Not a bad weight for an SE...
Oh yeah, and get rid of the cast iron water pump housing while you're at it. The 2nd gen came with an alloy version and will bolt right up for the most part.
Old 11-23-2008, 10:17 AM   #5
problem i found with that is the pump housing to engine flange like to leak where the one stud doesnt work out.
Old 11-22-2008, 11:25 PM   #6
P71
P71's Avatar
Actually they are increments of 20, but it kept flashing back and forth between 40 and 60 so I said 50.
You don't have to know anybody, just drive right through. Obviously there was nobody there on a Saturday night, so I didn't upset anybody. The scales are always on.
And mine isn't an SE. It's a plain-jane 12A powered GSL, albeit heavily optioned (I believe leather and the auto trans are the only things missing).
Michael Pinto
Vote for the ROTM!
Old 11-23-2008, 12:41 AM   #7
PercentSevenC
Custom User Title
PercentSevenC's Avatar
Makes me want to weigh mine. No emissions or AC, some engine bay simplification, and a lightweight exhaust, but it does have a 13B. The aluminum water pump housing and the Weber setup probably shave off several pounds.
Old 11-23-2008, 10:50 AM   #8
That is light...My FB without me in it weighs 2600lbs...But I do have a 13BT and a/c
Old 11-23-2008, 08:25 PM   #9
jtbshaw
ORD - Old Rotary Dude
jtbshaw's Avatar
You can get it there. My last 84 GSL build that I did weighed 2242lbs with me in it. I was about 220lbs then, and this was with a full tank of fuel (15-16 gallons in a fuel cell). My interior was gutted, lightweight racing seats, underneath the dash was gutted, spare tire and jack, engine compartment was cleaned out, even went down to installing carbon fiber pedals. On 100 shot of tha juice, the car dyno'd at 409 whp. Needless to say, it was a fun little car.
Old 11-23-2008, 09:13 PM   #10
need RX7
Clean S4 Nutswinger
need RX7's Avatar
Originally Posted by nolimitind View Post
weighed 2242lbs...dyno'd at 409 whp. Needless to say, it was a fun little car.
Sounds like it!!
Old 11-24-2008, 12:39 PM   #11
drewski86
Slow
drewski86 is on a distinguished road
Mine is 2430lbs. with me(~190), a few tools and less than a quarter tank. I'd guess it's 2200lbs. empty. '85 base with an '87 6port.
drewski86 is offline   Reply With Quote
Old 11-24-2008, 12:41 PM   #12
orion84gsl
You can go to any truckstop and scale your car. Most you will have to pay the scale fee which is usually between $7-$10. The attendants dont care, as long as you pay.
My buddy Sam and I weighed our cars at the Flying J in town and it came out as 2240 for his car and 2480 for mine. Full tanks and spare and jack in and without us in the cars. A few reasons why my car is so much heavier are I have a Sterling, and if you've ever picked up a Nikki you know they are rather heavy, and he only has ITB's which are fairly light. I have a full RB SP dual exhaust, whereas he has an SDJ header and thin piping. His car has most of the useless wiring stripped and I don't. He has the RE-Speed R&P kit and I still have stock steering (not for long though ). He has a Mariah front bumper which requires the removal of the stock steel bumper in place of a thinner, smaller metal frame. Mines stock. I also have a Rockford 400 Watt amp and he is using one or two much smaller amps and no rear speakers.
Old 12-10-2008, 03:36 PM   #13
eprx7
eprx7 is on a distinguished road
the last time I weighed my car was at the Toledo Pro Solo.
It scaled @2016 lbs. with 1/4 tank of gas, no interior except for the dash and a 15lb. race seat. I swaped out the steel sa bumpers for aluminum fb bumpers but used a hole saw to drill 2" holes in the aluminum to lighten it even more. theres no emissions or a/c or power steering on the car. i also have very light 13 x 7 panasports with hoosier cantilevered slicks. the car was weighed without me in it so you could add 220 lbs. to get the wieght down more I plan on gutting the doors and replacing the glass with lexan.
1979 SA F Prepared solo/ Track day car 12a w/Weber carb,RB header and exhaust,
Ground Control coilovers, camber/caster plates
GforceEng.panhard rod w/ tri-link,Panasports wheels w/Hoosier slicks.
eprx7 is offline   Reply With Quote
Old 12-10-2008, 03:51 PM   #14
i think i have seen your car once while picking up some parts, i could see it being 2016
Old 12-10-2008, 07:47 PM   #15
eprx7
I think you stopped out at my house to pick up some se parts I had for sale.
did you finally move to Colorado?
