Old 11-17-2008, 10:03 AM   #1
retaliate1st
retaliate1st's Avatar
retaliate1st is on a distinguished road
Thumbs down Slave/Master Cylinder / Oil Problem?
Ok, I've been searching and I've established that either my slave and/or master cylinder is shot... The clutch pedal sticks to the floor primarily in 1st & reverse. I can pull the pedal back up with my toe but, yeah... There seems to be little to no tension in the clutch pedal It's getting worse and worse.
However, as soon as this started happening, my oil pressure warning light started coming on and continues to do so; mainly when cold. My Autometer oil pressure gauge reads everything is a-ok, but the stock one reads low and light comes on. I've checked my oil like 4 times a day for the last 3 days - and it's topped off.
Do these two have any correlation? wtf rotary? Any help is greatly appreciated.
Thanks,
Brent
retaliate1st is offline   Reply With Quote
Old 11-17-2008, 10:21 AM   #2
SpooledupRacing
Guest
Posts: n/a
I cant see these being related issues AT ALL..
also the stock oil pressure gauge is not that accurate I would go by the autometer gauge and be confident with that over stock any day.
If you need a slave and master let me know I will shoot u a deal.
Old 11-17-2008, 10:33 AM   #3
Signal 2
Viable Fossil
Signal 2's Avatar
There's a single spade terminal at the stock oil pressure sender that typical gets dirty over time...it's right under the oil filter pedestal. Easy to do, but the senders go bad occasionally too.
Jim
VR R1 FD
Old 11-17-2008, 12:57 PM   #4
Brent
Sua Sponte
Brent's Avatar
Are you loosing any clutch/brake fluid?
As for the oil pressure gauge, like signal 2 said... clean the connector as it does get dirty over time. If not, the oil sending unit is somewhere between $60-80 brand new if I remember correctly. I would say it's the connection though since your autometer is still reading a normal pressure.
BTW, aren't you the guy that use to be stationed at Campbell? Aren't you at Irwin now? Good to have you here.
Brent
Old 11-17-2008, 05:07 PM   #5
mazdaman
mazdaman is on a distinguished road
if its the master cylinder for the clutch look under the carpet in the driverside floorboard if thats the problem your fluid will be their, had that problem in my 87.
mazdaman is offline   Reply With Quote
Old 11-28-2008, 10:03 PM   #6
IR Performance
I would change the master and slave at the same time. Typically when one goes bad, the other will fail shortly after. Also, put in an ss clutch line if you don't already have one. The stock rubber line tends to crack, often under the foam protective sleeve where it is hard to see.
www.irperformance.com
www.myspace.com/rotaryexperimentseven
irperformance@live.com
732-662-1794
Old 11-29-2008, 12:59 AM   #7
retaliate1st
i had the slave and master cylinder replaced @ mazdatrix. The whole time after, shifting was kinda rough and then 2 days later while driving, i hit a stop sign and then the car won't go into gear at all. i had to start it in first gear and limp it home, but it wouldn't shift - just got stuck in neutral. when the clutch pedal is depressed there's a strange sound... any ideas anybody?
Old 11-29-2008, 10:36 AM   #8
IR Performance
Check the clutch rod adjustment. Have someone press the pedal while you look through the access port under the trans to see when the pressure plate disengages.
732-662-1794
Old 11-29-2008, 04:43 PM   #9
Signal 2
Viable Fossil
Signal 2's Avatar
Or a broken clutch fork.
Jim
VR R1 FD
Old 11-29-2008, 07:35 PM   #10
rhackney
rhackney is on a distinguished road
or wedge collar and/or retaining ring
rhackney is offline   Reply With Quote
Old 12-11-2008, 08:23 PM   #11
IR Performance
If its the wedge collar then the clutch wont work at all. Either it holds or it doesn't.
732-662-1794
Old 12-21-2008, 01:41 AM   #12
Kwerks
FD Spirit
Kwerks's Avatar
Kwerks is on a distinguished road
I had the clutch pedal problem and it was actually the master cyl in my situation...the piston was unable to cope with the new pressure plate on my new clutch. I was tracing the problem and after further analysis the space plate between the slave cyl and the tranny housing has the ability to strip the bolts and one was in my case so I replaced it all. My slave was fine but i chose to replace it too. Be careful if you do replace the slave cyl because some of the mazda oem parts suffer from stripped valves that leak! My 1st one was stripped and I had to send it back to mazda.
best of luck...while your at it you may want to change brakes lines to stainless steel covered lines.
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car.
Horsepower is how fast you hit the wall, torque is how far you take the wall with you.
Kwerks is offline   Reply With Quote
Old 01-10-2009, 11:15 AM   #13
SHPmainMAN
SHP Motorsports
SHPmainMAN's Avatar
SHPmainMAN is on a distinguished road
if you are losing fluid, and you cant find out where, check in the bell housing of the tranny. I couldnt find a leak for the longest time and it was my slave cylinder leaking into the bell housing.
SHPmainMAN is offline   Reply With Quote
Old 01-10-2009, 04:49 PM   #14
speaking of which I too seem to be having hydraulic problems now. I think I will be ordering a new master cylinder and slave to replace the them (even though the master cylinder I have is probably at the most 8 months old--was brand new at the time--should I replace the master?). Previous to this I rebuilt the slave and that was a little over a year a go or so, maybe 18 months. I suspect the slave is the problem. I'm leaking fluid, not sure where, and I'm fairly certain that the slave is at fault and leaking into the bell housing.
I have a SS clutch line and the HDSS (Heavy Duty PP and Street/Strip clutch). I wouldn't think that puts too much stress on the hydraulics...
Old 01-11-2009, 06:02 PM   #15
SHPmainMAN
SHP Motorsports
SHPmainMAN's Avatar
take the slave cylinder out, and inspect it... i bet you found your problem. a lot of people with the same problem never relate the two for a bit, because they cant find a leak, and then the brake light on the dash comes on... and then they lose their clutch pedal... and all of a sudden theres a small river coming out from the bell housing. Well that's exactly how it happened for me. Get ahold of Ray at malloy mazda. he hooks it up.
