Old 10-27-2008, 09:47 AM   #1
1987 Turbo II - starts then dies
as of this morning, i now have this problem...
car was cold. Would start for a sec. Then as it rev'ed up alittle it would flat die like the ign. cut out (not like it stumbling and dying)
sooo. thoughts while i search?
Old 10-27-2008, 09:58 AM   #2
SpooledupRacing
Guest
Posts: n/a
so it did the cold start up then when it came down it just died...
what is the cars idel set at?
what degree is it outside?
will it start back up?
check for vac leaks, leaky injectors, spark plug condition
just a few idea.
Old 10-27-2008, 09:59 AM   #3
just a few idea.
its not a stumble out die its a rev up to 3000 (by my foot since i have no cold start) and then the tach just dies and you hear the engine whine down.
Old 10-27-2008, 10:08 AM   #4
SpooledupRacing
Guest
Posts: n/a
hummm.. so while u have the pedal depressed it just dies out.. or when u let off the gas it dies out?
Old 10-27-2008, 10:48 AM   #5
either or
Old 10-27-2008, 10:52 AM   #6
SpooledupRacing
Guest
Posts: n/a
hummm I would check for vac leaks... may be a big culprit.
Old 10-27-2008, 11:01 AM   #7
i plan on checking out the AFM as well. I am at work at the moment but i gives me something to do tonight.
Im just worried i may have a break in the wiring harness for the AFM
Old 10-27-2008, 11:39 AM   #8
SpooledupRacing
Guest
Posts: n/a
being a turbo car.. I just wonder if it is a coupler that has come loose and giving you a vac leak.. if thats the case and the leak is big enough it wont idle at all.
Old 10-27-2008, 07:22 PM   #9
and.......carbon killed the motor....
went to crank it and it spun as free as could be. Pulled the plugs and things are real low on compression. (lots of weak puffs, one good puff).
soo....thats that.
but on the brightside, i might be moving into a house soon!
Old 10-27-2008, 07:29 PM   #10
SpooledupRacing
Guest
Posts: n/a
DAMN!!! that blows.. sorry to hear buddy
Old 10-27-2008, 07:32 PM   #11
just an excuse to go faster
Old 10-27-2008, 07:41 PM   #12
need RX7
Clean S4 Nutswinger
need RX7's Avatar
Good luck.
Old 10-27-2008, 08:05 PM   #13
TehMonkay
let some atf sit in that biotch overnight.
also try jumpering the plug by the AFM for the fuel pump power.
Old 10-27-2008, 08:13 PM   #14
too late for that
