Old 10-26-2008, 09:12 AM   #1
dowrt9fc
dowrt9fc's Avatar
dowrt9fc is on a distinguished road
Turbo Exhaust manifold on FC
Hello,
I am a new member and wish to give credit to Kevin for rebuilding my trashed JDM T II motor. I have an SS Autochrome exhaust manifold and want to install in on the motor. The manifold required a t4 turbo, could I use my stock turbo with an adapter? What is the classification for stock turbo on 90 T II? THere is an adapter block made for T3 to T4.
Thanks
dowrt9fc is offline   Reply With Quote
Old 10-26-2008, 10:05 AM   #2
The stock turbo is SIMILAR to a T3, but it isn't a squared "4-bolt" flange, it just has a slant to it and will not bolt to a T3 flange.
You will need a T4 turbo as I don't believe there are any adapters.
Old 10-26-2008, 10:36 AM   #3
there t4 to t3 adapters on ebay but there quality is....sketchy.
Old 10-26-2008, 12:59 PM   #4
Well, mistake #1: Buying SSAutoChrome ANYTHING!
That shit is SUCH a rip off, and I only heard bad things about their products.
Old 10-26-2008, 02:06 PM   #5
SpooledupRacing
Guest
Posts: n/a
When his products first came out that s what I heard.. but alot of people I know now who use it say good stuff about it..
remember ALL aftermarket or custom made headers will eventually crack why not buy n inexpensive one have it last a couple years and then buy another..
Another thing u can do is send it to JetHot and have them jetcoat it that will help strenghten it and also u can weld in a few "helpers" to help support the weight..
Old 10-26-2008, 02:17 PM   #6
TehMonkay
Or spend $350 on a HKS cast manifold.
Old 10-26-2008, 02:35 PM   #7
need RX7
Clean S4 Nutswinger
need RX7's Avatar
The stock manifold is fine for the stock turbo.
Old 10-26-2008, 03:07 PM   #8
SpooledupRacing
Guest
Posts: n/a
yes but if u are changing to a T3 or bigger turbo then the stock manifold wont work..
also the stock manifold AND the hks cast manifold still cracks too.
Old 10-26-2008, 04:42 PM   #9
dowrt9fc
dowrt9fc's Avatar
If anyone has any positive experience with turbo headers manifold on T II cars, please share any dyno whp you may have comparing to stock.
SS Autochrome turbo exhaust appeared to have smoother exhaust flow than stock T II manifold, how much of an improvement could it help given the same set up with an exception of t4 turbo on the same motor?
Thanks
Old 10-26-2008, 06:33 PM   #10
josh18_2k
weld a support rod onto the manifold, close to the turbo, to help support he weight. that should help with the cracking
