Go Back   Rotary Car Club > Vendors and Group Buys > All Vendors > Rotaryshack
Rotaryshack www.rotaryshack.com (CA) Specializing in carbs, custom turbo kits, 1gen rx7 parts
Old 10-23-2008, 10:45 AM   #1
730RWHP12A
used parts section for sale cheap! check it out
used parts for sale section cheap!!! remember its a buyers market so all prices are negotiable! also if you dont see a part listed you can always request it
i will update this list weekly, so check back often to see if there is anything you want
13B racingbeat exhaust heade--- like new $180.00
used low mileage GSL-SE 13B motor with warranty $500.00
used 12A that runs with oil leak $300.00
used JDM FD 5 speed transmission, does not grind works great $400.00
nikki carb, race prepped $300.00
de-smogged 12A nikki intake manifold(egr and coolant passages have been welded up to reduce intake temperatures) a great power upgrade for cheap! $80.00
black sunroof latch assembly, round dial type( 80-83).......$60.00
exterior door handles fits 79-85 cars.....$25.00
exterior door handles fits 86-92 cars.....$60.00
84-85 power window switches..... $40.00
quiet good condition 79-80 transmission with warranty $350.00
grey 84-85 center armrest assembly, good condition, from a GSL model....$40.00
glass sunroofs avail, 80-85 ppg mfg.. good condition $200.00
new GT47-80 garret turbo.......$2,000
gsl=se afm (used)$40.00
msc engine rotors, housings available, please inquire within(pm)
turbo 2 intake manifold inlet adapters(2-1/2 straight inlet)..... $80.00
turbo 2 intake manifolds uppers and lowers available $60.00-$120.00
gsl-se suspension complete changeover includes everything you will need to convert your car ! brakes, rotors have approx. 2,000 miles, front struts were also replaced 4,000 miles ago with original kyb inserts.......$1,500
complete 85 12a non turbo motor.. was running great when removed for a turbo swap.. guaranteed to run good!!!..........$650.00
several msd efi fuel pumps.............$100.00 each
msc 91 convertable parts, air bag, turn signal switch, visors,ignition switch
fully built pinned bridgeported 13B 4 port( early type) 3mm apex seals new rotor hsgs, all new seals and springs, new oil o-rings and carriers, one year warranty $3,800
os geiken clutch/ flywheel setup, like new twin plate style for turbo 2 $800.00
os geiken clutch flywheel setup, missing pressure plate twin plate style for turbo 2 $300.00
rotaryshack.com
Old 10-23-2008, 10:54 AM   #2
ooooo....i need to get the next two paychecks in. Would you take like 50% down to hold an item for another two weeks?
Old 10-23-2008, 11:59 AM   #3
730RWHP12A
you dont need a deposit, i will hold an item for ya
rotaryshack.com
Old 10-23-2008, 12:06 PM   #4
I want / need the clutch/flywheel for the turbo 2. Does it come with the counterweight?
Old 10-23-2008, 01:55 PM   #5
730RWHP12A
if i have the right counterweight ill throw it in.
rotaryshack.com
Old 10-23-2008, 02:13 PM   #6
SpooledupRacing
Guest
Posts: n/a
I know its not on here but I figured I would ask..
drivers rear speaker cover/grill with no breaks/cracks
Old 10-23-2008, 10:27 PM   #7
turbovert91
turbovert91's Avatar
turbovert91 is on a distinguished road
Any other vert parts? Specifically the bracket/capacitors for the airbag system?
turbovert91 is offline   Reply With Quote
Old 10-24-2008, 08:42 AM   #8
730RWHP12A
do you mean the sensors that mount to the core support? air bag control module is sold
rotaryshack.com
Old 10-24-2008, 09:36 AM   #9
turbovert91
Not sure, I'm talking about the blue boxes attached to a bracket on the steering column under the dash...here's a pic of one:
Old 10-24-2008, 02:00 PM   #10
730RWHP12A
ill look for it. thanks for the pic!
rotaryshack.com
Old 10-28-2008, 12:30 AM   #11
motor blew in the turbo II today, so i guess this is no longer on my list.
Old 10-29-2008, 02:20 PM   #12
730RWHP12A
oh, no!! thats no good.
i have used motors too
rotaryshack.com
Old 03-05-2009, 12:05 AM   #13
3rd and final 7
3rd and final 7's Avatar
3rd and final 7 is on a distinguished road
Hey Robert if you have a TII ACV how much would that be?
3rd and final 7 is offline   Reply With Quote
Old 03-05-2009, 11:38 AM   #14
730RWHP12A
yes $25.00 shipped. a pic of the exact acv valve you want to replace would be great as there are some minor differences.
rotaryshack.com
Old 03-05-2009, 12:43 PM   #15
3rd and final 7
i dont have the ACV it self bc i bought the intake mani w/o it but if a pic of the mani will help as far as which one that i have?
