Go Back   Rotary Car Club > Classifieds > 2nd Gen Classified > 2nd Gen RX-7 Parting Out
2nd Gen RX-7 Parting Out Parting Out Mazda RX-7 You must have over 4 parts to list your items here. No new parts allowed.
Old 10-21-2008, 03:20 PM   #1
Comitatus
Comitatus's Avatar
Comitatus is on a distinguished road
Exclamation Huge Partout! S5 FC TII - HBP- Tons of NICE/QUALITY/AFTERMARKET parts
A seal let go in my motor, and my luck, pride, and wallet can no longer handle it. So I'm sad to say, that I'm parting out my beloved machine.
This car recently tuned on low boost made 369whp @ 14psi on a DynoDynamics dyno. That is about 435whp on a dynojet. The best 1/4 mile time I ran in this car was a 12.0 @ 120.93mph. That was last year on a different tune and 12psi. This year my first pass in the car netted a 12.4 @ 122mph which boost gauge read 13psi, launching easy/ 2.4 sec 60'. I know this car had a high 11 second pass @ 123-124 mph on low boost/street tires.
I have owned this car for almost 5 years. I bought the car with 109K miles on the odometer. It now has just over 112k miles. The motor was freshly built on 8/10/08. I put about 700 miles on this motor before the seal went. Clean title. Registered in Ohio.
I have a HUGE list of parts that are on this car. I'll do my best to take pictures of everything, so please be patient if I don't have one up right away.
All of these parts are either new, like new, or have a very small amount of mileage on them. I'm pricing everything to sell because I want this stuff gone. My loss is your gain. I'd like to sell the big stuff locally to stay away from shipping, but I will ship items at the buyer's expense.
I can do Paypal, but buyer will need to add 4% to the total cost to cover fees.
Prices listed in RED, and does not include shipping. If you want to buy multiple things, I'm willing to wheel and deal.
Located in Cincinnati, OH 45241.
Engine
Motor is torn down currently.
Selling complete shortblock AS IS with following parts (last rebuild)- $1,500
• S5 TII FC3S ShortBlock
• Half Bridgeport Irons by BDC Motorsports
• Ported Rotor Housings by BDC Motorsports
• Atkins 2mm Apex Seals
• OEM Mazda 2mm Apex Seal Springs
• Mazda OEM “O-ring kit”
• New OEM Oil Pump Chain
• New OEM Stationary (main) Gear Bearings
• New OEM Rotor Bearings
• New OEM Side Seals and FD Springs
• New OEM Thrust Bearings
• New OEM Oil Control Ring Springs Kit
• Solid Corner Seals and Competition “Race” Springs
• Later/Thicker Cast Dowel Land Rear S5TII Plate
• New OEM Front Plate (Thick Dowel Land)
• New OEM Dowel Pins
• FD Oil Pressure Regulator
• Racing Beat Oil Pan Baffle Plate
• New Water Pump & OEM T-Stat
• Banzai Racing Oil Pan Brace & Stud Kit - $110
• Mazdatrix Oil Filter Pedestal - SOLD
• Powder Coated FD UIM and Polished TB - $375 includes S5 LIM, spacer, and hardware
• Custom Port Matched FD UIM to FC LIM Spacer
• Modified Greddy TB Elbow - $80
• Mazda Racing Competition Pulley Set - $175 - Has Rare Earth Magnets in Crank Pulley
• New FD Alternator - $100
• Banzai Racing Polyurethane Motor Mounts - $100
Transmission
• ACT HD Pressure Plate - SOLD
• ACT 6 Puck Un-sprung Clutch Disc - SOLD
• ACT StreetLite Flywheel - $210
• Banzai Racing Polyurethane Transmission Mounts - $35
Cooling
• Koyo Aluminum Radiator - $300
• Black Magic Extreme E-fan - $275
• Samco Sport Coolant Hoses - $90
• Racing Beat Stainless Braided Oil Cooler Lines - SOLD
• Yonaka 26x12x3 Core Intercooler $275
• 4” Turbo Intake Pipe - $30
• K&N Cone Filter - $30 - 4" filter
• Custom IC Piping - 2.5” Turbo side & 3” Intake side - Powder Coated - $175
Exhaust
• Linder Power Systems Custom Divided Manifold (Ceramic Coated) - $800
• Dual SS EGT bungs (1 per Runner)
• Linder Power Systems Custom 3" to 3.5” Downpipe (Ceramic Coated) - $300
• Dual Tial 38mm Wastegates - 11.5psi springs - $200 per WG
• Custom 3.5” Stainless Steel Single Exit Exhaust - $800
• Borla XR-1 Oval mid-muffler
• Magnaflow Race Series rear muffler
Turbo
• Polished Garrett T04R w/ P-trim Exhaust Wheel - $700
• Divided 1.32 A/R Exhaust Housing (HPC Coated)
• 3” V-band Exit
• -4AN Stainless Braided Oil Feed -$100 for both feed/drain lines w/ flanges.
• -12AN Stainless Braided Oil Drain
• Gotham Racing Turbo Blanket - $125
Fuel
Fuel Kit (no injectors or pump) - SOLD
• KG Parts FC Fuel Rails - SOLD
• Aeromotive 10 Micron Fuel Filter - SOLD
• Aeromotive A1000 FPR - SOLD
• Marren Fuel Pulsation Damper - SOLD
• -6AN Stainless Braided Lines w/ Earl’s Aluminum Fittings (fuel filter forward) - SOLD
• 2 x 720cc Siemen Deka Injectors - $120 - Pending Sale
• 2 x 1680cc Bosch Injectors - $150
Ignition
• BMEP IGN-1A Coils - $320 including custom Magnecor wires
• Custom Magnecor R100 10mm Plug Wires
• NGK R6725-105’s - $80 Excellent Condition
Electronics
• Haltech S3 Hall Effect Sensor - $200 includes custom bracket
• Custom Hall Effect Sensor Mounting Bracket by Ludwig Motorsports
• Turbosmart E-boost 2 60psi Boost Controller w/ twin LED ring - $450 including dual solenoids and LED ring
• Dual E-boost Solenoids (1 per WG)
• Innovate Motorsports LC-1 Wideband - $340 - Includes XD-16 Air/Fuel Guage
• Innovate Motorsports XD-16 Air/Fuel Gauge
• Optima Red Top Battery - $80
• Greddy Turbo Timer - $90
• Greddy FC RX7 Turbo Timer Harness - $10
Suspension
• Energy Suspension Full Bushing Set - Black - $100/Brand new, still in Box
Brakes
• Brembo Blank Rotors – Slotted, Dimpled & Zinc Coated - $200 for front and rear
• Hawk HPS Brake Pads - $75 F/R
• Mazdatrix Stainless Steel Brake Lines - $70
Gauges
• Defi Link Meter 60mm Oil Pressure - $200
• Defi Link Meter 60mm Exhaust Gas Temperature - $200
• Defi Link Meter 52mm Fuel Pressure - $190
• Defi Link Meter 52mm Oil Temperature - $150
• Defi Link Meter 52mm Water Temperature - $150
• Defi Link Meter 80mm Tachometer w/ Link Indicator Light - $150
• Defi Control Unit II - $100
Interior
• Corbeau FX1 Pro Seat - $200
• Corbeau 3” 5 Point Cam-Lock Harness - $120
• AutoPower 4 point Roll Bar w/ Diagonal Brace & Harness Bar - $400 - Pick up Only
• AutoVation Aluminum FC3S Pedals - $75
• Voodoo Racing Shift Knob - $30
• Speed Machine Performance Carbon Fiber Radio Surround - $100
• Speed Machine Performance Carbon Fiber Dual Gauge Pod - $150
Miscellaneous
• Tial 50mm BOV - $200
• Remote Terminals Installed in Engine Bay - $15
• Jazz Vented Oil Breather - $60
• Jazz Recirculating Coolant Overflow - $20
Exterior
• ShineAutoProject Carbon Fiber Sexy Style Vented Hood - $650
• Sparco Polished Aluminum Hood Pins - $35 Brand New - Still in Package
Alcohol Injection
• Custom Progressive Alkycontrol.com kit - $650 - will include 4 gallons of methanol
• Twin M10 nozzles
• 1 gallon JAZZ fuel cell - modified for pure alcohol
• Pump modified for pure alcohol
• SS braided lines
• PAC controller
• Check Valve
• Low Level LED and Injection Indicator LED
Comitatus is offline   Reply With Quote
Old 10-21-2008, 03:46 PM   #2
How much for the meshies??
Old 10-21-2008, 03:47 PM   #3
would you be willing to ship a larger item (namely the seat and bracket). obviously i would be paying shipping
Old 10-21-2008, 03:55 PM   #4
SpooledupRacing
Guest
Posts: n/a
If I run into some cash soon I will be snagging up a hand full orf parts..
Old 10-21-2008, 05:56 PM   #5
Comitatus
Comitatus's Avatar
Not sure I'm selling those just yet, I'd have to find 2 other spare tire wheels so I could keep the chassis a rolling shell.
They have 225/50/16 Kumho Ecsta SPT's on them. Like new with only 3K easy miles on them (breaking in the motor/s)
Probably $500 for wheels and tires.
Old 10-21-2008, 05:57 PM   #6
Comitatus
Comitatus's Avatar
Shouldn't be an issue if I can find a box.
Old 10-21-2008, 06:13 PM   #7
RotaryXperiment
got videos of it running?
Old 10-21-2008, 07:32 PM   #8
how did the seat sit? any lower than stock?
Old 10-21-2008, 08:46 PM   #9
Comitatus
Comitatus's Avatar
What do you mean?
Old 10-21-2008, 08:48 PM   #10
Comitatus
Comitatus's Avatar
Yep. A couple inches at least, hence the custom made bracket. I also have the Corbeau Sliding Double Lock bracket if you'd want that instead.
I'm 6'4" if that gives you an idea.
Old 10-21-2008, 10:08 PM   #11
real interested now. im 6'1"
Old 10-21-2008, 11:21 PM   #12
turbovert91
turbovert91's Avatar
turbovert91 is on a distinguished road
I'm interested in the Banzai oil pan brace kit if you'll go lower. Brand new ones are $125 shipped, hardly more than your $110+shipping would cost...
I'd also like your NGKs and possibly the K&N, do you have pictures of these? How many miles are on the plugs?
turbovert91 is offline   Reply With Quote
Old 10-22-2008, 12:06 AM   #13
I'm interested in the:
oil pedestal
Oil cooler lines
Old 10-22-2008, 09:13 AM   #14
Comitatus
Comitatus's Avatar
Would probably work very well for you then. Let me know.
The pan brace is pretty much new. Was on the car for 2 months (700 miles). I can ship that single piece for $5. I'll do $110 shipped for it.
I can get pictures of the K&N and NGK's shortly. Filter has about 1K miles on it, NGK's probably a total of couple hundred (used very little).
$110 for NGK's and Filter.
How does $225 shipped for everything sound?
oil pedestal
Oil cooler lines
How about $160 shipped?
Old 10-22-2008, 09:40 AM   #15
Comitatus
Comitatus's Avatar
Added Parts
