Old 10-19-2008, 06:06 PM   #1
My 8 with Mazdaspeed catback.
I installed the catback today and I have to say, its not bad... Maybe 2-3 hp gain and noise is bit more throaty.
Here are some pics
Before
After
Old 10-20-2008, 01:51 AM   #2
Nutsid
Temporarily insane.
Nutsid's Avatar
Very good looking car. How much was the cat back system?
Kindle
Nook
Old 10-20-2008, 12:31 PM   #3
Snakebite202
Clutch, gear, gas...
Snakebite202's Avatar
Snakebite202 is on a distinguished road
Hey Herb, would you happen to have your oem front bumper still?
Lighting Yellow SE3P - 6 Speed MT - Zoom, Zoom mother f**ker!
Snakebite202 is offline   Reply With Quote
Old 10-20-2008, 12:58 PM   #4
Nexcis
Nexcis's Avatar
Nexcis is on a distinguished road
Looking very nice Phil! Did you do the work yourself or someone else?
'94 VR FD - Mod List
Nexcis is offline   Reply With Quote
Old 10-20-2008, 01:29 PM   #5
I don't have my original bumper.. Sorry..
Gianny, I did the work with a friend of mine and used his lift. Took about an hour to do the exhaust and check my tranny and diff fluids.
Hardest part was removing the rubber hangers. Key was to use WD-40, long nose pliers, and crow bar. Next hardest part was bolting the catback flange to the cat. The OEM bolts are spring loaded and that was kind of tricky and good to have second hand.
We used couple of Vice to hold things together and after about 15 mins, we got it on..
Also, the pipe between the cat and the muffler... The hanger was bit tricky. Make sure to pull out the rubber hanger off the car, install on the the pipe hanger, and then put it on the car hanger.. Otherwise, its nearly impossible to hang the mid section pipe... Trust me, we tried
Overall pretty simple job and noise is pretty good.. Not too loud and deeper tone. HP gain is almost NONE I put HKS twin on first and Catback didn't make much of a difference... maybe bit more on top end.. and my butt dyno says maybe 2-4HP max..
Looks.. well, it looks pretty stock except it says MS on it.. Quality is top notch! All SS construction and compare next to stock, much better design and lighter by about 10lbs.. 10lb is just a guess..
Oh, I bought it used about a year ago and I don't quite remember how much.... I think $400-450 used?? Don't recall..
Old 10-20-2008, 01:42 PM   #6
Nexcis
Nexcis's Avatar
Nice! I'm debating about going the same route. I haven't' decided yet though.
That almost sounds like a write up for RCCD!!! hint hint
Old 10-20-2008, 02:22 PM   #7
Unfortunately, I didn't take any pics
Old 10-20-2008, 03:01 PM   #8
Nexcis
Nexcis's Avatar
Sounds like you need to take it all down and redo the work
Old 10-20-2008, 04:25 PM   #9
sumdeus
sumdeus's Avatar
sumdeus is on a distinguished road
^ What he said!
sumdeus is offline   Reply With Quote
Old 10-23-2008, 08:09 PM   #10
VR8
Dragon Slayer Alumni
VR8's Avatar
VR8 is on a distinguished road
Looks good Phil....and I'm with you, those spring loaded bolts are a fiesty bitch!
VR8 is offline   Reply With Quote
Old 10-26-2008, 04:47 PM   #11
warwickben
sa rat rod
hey guys i feel dumb asking but could you guys recommend a good cat back that would be street legal in mass.
Old 10-26-2008, 06:26 PM   #12
MS catback should be legal in 50 states as Mazda sell them and sells them with warrantee.
Old 10-26-2008, 07:26 PM   #13
sumdeus
sumdeus's Avatar
I have Hymee and love it. I have heard MS ones before and they too sound very good.
Legal? Sound legal?
