Old 10-17-2008, 05:19 PM   #1
Jeff4764
Jeff4764 is on a distinguished road
spark plug wires
Ive been having a problem with starting my car and idleing when its hot. most recently ive noticed It misses once in a while. Ive changed the coils, spark plugs, coolant temp sensor, intake air temp sensor, all fuel injectors, bypass air control valve, and starter. The only thing i havent checked is the spark plug wires. I just looked at them a few minutes ago though and noticed there is a white powder on them underneath the plastic tubes that cover each one. They are the original wires from 1987. is this a plausible thing that could possibly be my problem.
Jeff4764 is offline   Reply With Quote
Old 10-17-2008, 05:26 PM   #2
ZGN
Administrator
ZGN's Avatar
If those things are the original ones, it's time to replace them!
Old 10-17-2008, 05:40 PM   #3
Jeff4764
they say 1987 right on them theyre definately original. Im hopeing thats the problem, but at the same time would be pretty angry after spending so much money on trouble shooting.
Old 10-27-2008, 10:22 PM   #4
mfisher12
mfisher12's Avatar
mfisher12 is on a distinguished road
yup you need wires
mfisher12 is offline   Reply With Quote
Old 10-28-2008, 01:08 AM   #5
White powder is bad.
That's a sign that it's arcing.
More accurately, it's arcing inside the boot.
That means there's no secure connection from the coil tower to the spark plug wire connector - it's arcing to make this connection.
Old 10-28-2008, 05:10 AM   #6
SpooledupRacing
Guest
Posts: n/a
yeah bad news replace those plug wires.
Old 10-28-2008, 08:03 AM   #7
http://www.partsgeek.com/gbparts/199...ek+Google+Base
There you go!
Petty Cheap replacement!
Old 10-28-2008, 08:04 AM   #8
SpooledupRacing
Guest
Posts: n/a
hell I have a set with less then 800 miles on them u can have them for 20.00 and i will ship them for FREE to lower 48
