Old 10-13-2008, 01:50 PM   #1
Alternator Rebuild parts
Just picked up an FD alternator and had it tested after I cleaned it. It tested dead (probably due to the cleaning), ie: not energizing at all. So long story short I'm in need of a rebuild kit. Where can I pick up the parts for it? I figure full on rebuild. Brushes (even though they look good), Diods, everything except the case, shaft, stator (can a stator go bad?), you get the picture.
So where do I get them?
What will I need?
I figure diods, rectifier, and brushes. Should I look for anything else while i'm in there?
Old 10-13-2008, 02:31 PM   #2
okay, I found a place that sells the parts, but now what parts do I need... I don't have any markings on this alternator (No sticker, etc)
http://www.transpo.de/Catalog/Browse.htm
Old 10-13-2008, 02:46 PM   #3
Need some more help/confirmation Identifying parts.
Regulator
http://www.transpo.de/cgi-win/product.exe?IM830
Rectifier
http://www.transpo.de/cgi-win/product.exe?IMR10068
Butt-end Bearing
http://www.transpo.de/cgi-win/product.exe?108004W
Slip Rings (steel and copper... which one's better?)
http://www.transpo.de/cgi-win/product.exe?13179001
http://www.transpo.de/cgi-win/product.exe?13179002
Old 03-25-2011, 10:04 PM   #4
Look what I stumbled upon!
Regulator:
http://store.alternatorparts.com/par...ternators.aspx
Rectifier:
Still can't find stators or rotors.
Old 05-23-2017, 09:34 AM   #5
FC Zach
FC Zach's Avatar
Regulator:
Rectifier:
Holy thread revival! !
Just wanted to say thank you for sharing the links. . Before searching here for possible rebuild parts I was asking myself if it was even worth it to rebuild a S6 alternator. Considering the price of a new or even rebuilt unit, I'd say definitely! ! ! This is the way to go, thanks again!
1993 Yamaha GTS1000
1992 Celica Turbo AllTrac
1987 RX7 Sport
1979 Yamaha G1, KM24 powered
1975 Dolmar KMS4
Old 06-04-2017, 08:32 PM   #6
FC Zach
FC Zach's Avatar
I rebuilt my alternator by replacing the bridge rectifier and voltage regulator this weekend. I had a little trouble with assembly after soldering the new components but that was user error, dummy me thought the spacer (that should go between the rotor and bearing) went between the pulley and bearing. . . needless to say it was locking up every time. Anyways, I took it to Oreilly's to have tested and it passed! Success! !
1993 Yamaha GTS1000
1987 RX7 Sport
1975 Dolmar KMS4
