Old 10-11-2008, 08:03 AM   #1
SpooledupRacing
Guest
Posts: n/a
Comp diff mount vs OEM diff mount
Ok I have begun to completely redue the entire suspension.. the last steps are to either put on a perfectly good OEM mount or put on a comp mount from mazdatrix..
I have redone ALL the bushings with solid mounts and urethane bushings my question is:
Is the comp diff mount that much better then the OEM mount or not?
This is on a turbo drivetrain and I am putting in an lsd plans for big power I just want to know for those who have used them is it worth the change? should I save the 100.00 and just use my current stock mount (I have 2 both look just fine)
any info would be great..
THX.
