Old 10-02-2008, 05:18 PM   #1
Jeff4764
Jeff4764 is on a distinguished road
fuel injectors??
I just bought fuel injectors and 3 of them look good but one of the doesnt have the filter/screen or whatever it is in it. there is supposed to be one in all of them right? Also I can only find two injectors up on top under the throttle body, where are the other 2?
Jeff4764 is offline   Reply With Quote
Old 10-02-2008, 05:36 PM   #2
Rotary#10
Rotorhead
Rotary#10's Avatar
some pics would help please
Currently running:
90 N/A GTUs..
Running project car
89 N/A GTUs in Black #2
10/6/18
Old 10-02-2008, 06:32 PM   #3
Jeff4764
i dont have any pics and i cant take any i put the two in already and havent tried starting it yet. Right on top of the injectors on the inside there is a little screen looking piece that is missing from the one. Im pretty sure its supposed to have one, it wouldnt make sense for it not to. I guess my real question is, is it dangerous like that or will it be ok
Old 10-02-2008, 08:53 PM   #4
RoughRex
Out of Nickels and Dimes
RoughRex's Avatar
Two injectors mounted on top of the Upper Intake Manifold, two mounted under it. They all should have filter baskets, O-rings, Grommets, and Pintle caps. Make sure you bought the correct injectors for your year and engine type, they are not all the same. If need be, you can pull a filter basket out of one of your injectors to put it in the old one but you'll have a really hard time getting it out without damaging it. I recommend sending them off to get professionally cleaned by KGParts. They are listed in the vendor section. It's cheap, they replace everything I just listed and they have a fast turn around time.
1988 GXL
RoughRex is offline   Reply With Quote
Old 10-03-2008, 06:15 AM   #5
Jeff4764
I did find the other two. also all injectors old and new have the same part # on the side.
If I can find injector cleaning kit or somewhere where i can get the filter basket that would be awesome. anyone have any ideas
Old 10-04-2008, 04:21 PM   #6
RoughRex
RoughRex's Avatar
Be carefull. IIRC both the high and low Imp injectors show the same part # on the side. You can tell them apart by the connector. The High Imp injectors have an offset "key" and the low Imp have a centered key. Your 88 should have High imp. injectors. Also, I don't think you can get an "injector cleaning kit" although, I could be wrong. If you wanted to clean them yourself you would probably have to let them soak in a vat of carb cleaner or something overnight. Then you would be left trying to source the pintle caps, grommets, filter baskets, & O-rings. I would wind up costing you more to get the parts than it would if you sent them out to be cleaned. (I looked when I went through this)
1988 GXL
Old 10-04-2008, 06:29 PM   #7
Year Engine Plug Size Colour Part #
84-85 13B NA, low square center, 680cc, orange, 195500-0900
86-87 13B NA, low square center, 460cc, red, 195500-1350
86-87 13B Turbo, low square center, 550cc, tan, 195500-1370
88 13B NA, high square offset, 460cc, purple, 195500-1350
88 13B Turbo, high square offset, 550cc, purple, 195500-1370
89-91 13B NA, high oval center, 460cc, red, 195500-2010
89-91 13B Turbo, high oval center, 550cc, purple, 195500-2020
www.witchhunter.com
www.rceng.com
kgparts
its worth it to get them cleaned, they replace everything and you make sure you don't have one that is too weak making a rotor run lean.
Old 10-08-2008, 06:06 AM   #8
KGParts
KGParts's Avatar
KGParts is on a distinguished road
As already mentioned, you should have them cleaned and tested. The Injector Cleaning division of KGParts can be found here: http://injector-rehab.com/
It sounds as if you would rather do it yourself... so.. here you go:
http://rotarycarclub.com/showthread.php?t=1233
RX7 Fuel Systems
www.KGParts.com
Fuel Injector Flow Testing & Cleaning Service
www.Injector-Rehab.com
KGParts is offline   Reply With Quote
