Old 09-29-2008, 07:13 PM   #1
Pourman
Pourman's Avatar
TNS relay
I noticed my Car battery would die and I had to jump the car off over the weekend , everything looked and seemed fine ... tonight right before I tried to start it I heard a noise coming from under the hood ... sounded like the fan motor was on , but I popped the hood , and coming from the relay box the TNS Relay was "Buzzing" ... I pulled it out , the noise stopped , plugged it back in and the relay itself would vibrate loudly when the relay was reconnected ... I read that the TNS relay controls all the lighting , except for the headlights , but I've never seen a fuse or a relay vibrate or buzz like that WTF ??
_
Old 09-30-2008, 01:37 AM   #2
Pourman
Pourman's Avatar
Found the problem ... FIXED
Old 09-30-2008, 08:47 AM   #3
Brent
Sua Sponte
Brent's Avatar
What was it if you don't mind sharing?
Old 09-30-2008, 05:21 PM   #4
Pourman
Pourman's Avatar
Pulled all the relays and swabbed the contacts IN the relay box , and inside the relay switches themselves with alcohol ... then , disconnected the battery while I was cleaning relays to reset the ECU (just to start over) ... everything functioned fine today , but it's a 15 year old car so I guess these things will happen from time to time
