Go Back   Rotary Car Club > Classifieds > 1st Gen Classified > 1st Gen RX-7 Cars For Sale
1st Gen RX-7 Cars For Sale Buy or Sell your Car only!! No Parts!
Old 09-28-2008, 11:30 AM   #1
FS: my 1982 Rx7 ~1750 firmish
i am offering it up for sale but do not expect me to take low ball offers on it. I can and will wait to get a trailer and tow it colorado if i have too. but if it sells, it sells.
The car is located just east of cleveland, ohio.
the build thread is HERE
The car is a 1982 GS silver with black interior. Seats are isuzu impulse turbo seats. They sit lower, and have adustments for seat height and lumbar plus adj. side bolsters. Interior is in very very good condition and the body is extremely nice. It even has the undertray.
Engine is a stock 12a with about 71,800 on the ODO, with a header. The rest of the exhaust needs to be made. Has a tweaked Nikki from Pete. Also has a Holley FPR, and carter fuel pump. Car is not running currently due an issue with low fuel volume to the pump. Tank will need dropped and cleaned or inspected. From the outside, the tank is immaculate though. But it does start off starting fluid. All emissions are removed, MOP is disabled. Also has e-fan that needs connected, FC oil cooler. Also has new thermostat.
Transmission is a stock 12a with Lucas oil in it. Clutch is new OEM replacement.
Suspension is from a GSL-SE. Has eibach springs, adj. illumias in the front. Needs rear shocks. has ST sways bars. Has Datsun 6 spoke wheels, with 205/60 R15 goodyear tires that are basically brand new.
Brakes are stainless steel lines. Old oem pads and rotors are on it. The driver's front caliper has the bleed broken off so i could not finish bleeding the system.
Car will be coming with the 4.076 LSD GSLSE thrid member, the 4.78 open diff will be coming out if it sells. UNLESSS you want to add 200 dollars to the cost. Then its yours.
This car is in very nice shape and comes with some very nice items. Does not need much work to start being driven around i just dont have time to finish it in Ohio. As stated, low balling is not worth it to me. I would rather pay 1000 to ship it if that is the case. I have almost 200 hours into his car and lord knows how much money now.
so 1750 w/o 4.78 gears or 1950 with. You pick it up
