Old 09-24-2008, 06:49 PM   #1
BLKTOPTRVL
BLKTOPTRVL's Avatar
*&&@#* Oil Injectors
I'm having one hell of a time getting the oil injectors back in tight (the ones on the engine - not the manifold).
The wrenches I have are not narrow enough at the head to slip between the head (red) and the base (yellow) to get a bite on the bolt (green).
So, what did you do to get these tight? Did you take a 14 mm and grind down one or more faces, or were you able to find a wrench that is thin enough?
Old 09-24-2008, 08:15 PM   #2
Looks to me like your oil injectors need some TLC. I just used a wrench, but my injectors were significantly better condition.
Old 09-24-2008, 08:42 PM   #3
Polito Racing
so you got pistons oh wow
Polito Racing's Avatar
Polito Racing is on a distinguished road
when I have problems getting them out I use a big spark plug socket from the top and rachet it out. I beleive the one I use is a 13/16. allways works!!!!!
Polito Racing
2000 F-350 SD (Daily Driver)
2002 CBR 954RR (Back on the Road)
1987 RX-7 Turbo II(red bullet!!)
Polito Racing is offline   Reply With Quote
Old 09-24-2008, 08:53 PM   #4
BLKTOPTRVL
BLKTOPTRVL's Avatar
Hmmm, the big heads didn't look that strong to me. Figured I would snap them off if I put a wrench on the head.
Old 09-24-2008, 09:01 PM   #5
BLKTOPTRVL
BLKTOPTRVL's Avatar
Looks like it is a moot point on the old injectors... Only one of the four passes the suck test. So, I guess I need to lube up (pun intended) and go see the mazda parts man.
Old 09-24-2008, 09:14 PM   #6
Polito Racing
did you do it? did it work?
Polito Racing
Old 09-24-2008, 09:17 PM   #7
BLKTOPTRVL
BLKTOPTRVL's Avatar
No, there is no point to trying to get them in tight now. Three of the four are shot.
Old 09-24-2008, 09:19 PM   #8
i ground down a wrench to fit
Old 09-24-2008, 09:21 PM   #9
BLKTOPTRVL
BLKTOPTRVL's Avatar
That's probably what I will do after I get a new set of injectors (nozzles).
Old 09-25-2008, 05:35 AM   #10
BLKTOPTRVL
BLKTOPTRVL's Avatar
Question:
I will call Mazda later today to get a price on the injectors. Mine need to be replaced because they are only supposed to pass vacuum in one direction. Mine pass air in both directions.
I imagine the Mazda price will be relatively high. So, instead of replacing the bad ones I have, can't we just put check valves upstream from the bad injector nozzles as I show in the picture? I can find these valves for as low as two dollars each.
Old 09-25-2008, 06:44 AM   #11
Get some from Mazdatrix, or call Ray at Malloy Mazda.
Fero313 bought like 20 oil injectors used before actually getting 4 that worked, to me that isn't worth it.
Old 09-25-2008, 07:54 AM   #12
BLKTOPTRVL
BLKTOPTRVL's Avatar
I checked the MaxdaTrix site and didn't see any on their site and I think Mazda doesn't sell them anymore.
I may just have to add checkvalves inline.
Old 09-25-2008, 10:35 AM   #13
http://mazdatrix.com/b62.htm
about halfway down right above the OMP lines.
Old 09-25-2008, 11:36 AM   #14
BLKTOPTRVL
BLKTOPTRVL's Avatar
Thanks for the look-out. Don't know why I didn't see them before.
Mallory is selling them for a little less than Trix right now. But from what I read, new ones can go bad within 10K of purchase. So, I am going to try the check valves first (at < $8.00 a set) before going to the new nipples.
Thanks again.
Old 09-27-2008, 11:00 AM   #15
BLKTOPTRVL
BLKTOPTRVL's Avatar
Why so many check valves?
Mazda put a individual check valve into each of the oil injector nozzles.
Does anyone know if the check valve is at the base of the injector to block the backwards flow of oil? Or is it at the top of the injector to stop the backwards flow of air?
