Old 09-24-2008, 10:04 AM   #1
BLKTOPTRVL
BLKTOPTRVL's Avatar
Gasket Descriptions
Some of you might have noticed that some gaskets are getting hard to find.
As the cars get older they might be impossible to find. So, I think it would be nice if wemeasured and published the specs of them now so we can make our own later if we have to.
Any comments/suggestions for improvement would be welcome.
http://www.youtube.com/watch?v=6rx5hGKt1PY
So, what if we started a guide to gaskets? Like so...
Old 09-24-2008, 10:06 AM   #2
BLKTOPTRVL
BLKTOPTRVL's Avatar
Arrow Air Control Valve Gasket
Engine: 1988 6 Port
Material: Cardboard
Sealant: No sealant needed.
Thickness: .041" Thick
This gasket seems not to be a perfect fit for the car and needs to be adjusted.
Pics:
Old 09-24-2008, 04:49 PM   #3
BLKTOPTRVL
BLKTOPTRVL's Avatar
EGR Gasket
Engine: 1988 6 Port
Material: Cardboard
Sealant: None
Thickness: .043
Seems to be a perfect fit.
Note: Before reinstalling the EGR Valve clean out all the carbon with pipe cleaners.
Old 09-27-2008, 09:52 AM   #4
BLKTOPTRVL
BLKTOPTRVL's Avatar
Port Valve Actuator to LIM
Engine: 1988 6 Port
Material: Cardboard
Sealant: None
Thickness: .023 Inch
Old 09-27-2008, 10:15 AM   #5
BLKTOPTRVL
BLKTOPTRVL's Avatar
I did a little experiment today.
I took a shot of this gasket...
http://rotarycarclub.com/showpost.ph...27&postcount=4
Then adjusted the size of the photo so that the dimensions match, printed it out.
What I got was a almost perfect match for the original gasket. The photograph still needs a little adjustment to match the original exactly.
Of course this is just one test, but I believe that using good photography, and software I can easilly produce new gaskets of the correct size. Then using the cutting machine produce good duplicates.
I am going to try a few after the machine arrives and see how close I can get them.
Old 09-28-2008, 09:55 PM   #6
if someone can get me a downloaded copy of Solidworks, i can make a 3d model of each gasket or any part and that can be used to make a plan for the gasket which can be used to produce any gasket...period.
Old 10-21-2008, 06:31 AM   #7
Cp1
Cp1's Avatar
what nobody ever heard of a mallet and cork here? jeez its easy to make a gasket.
