Old 09-23-2008, 12:22 PM   #1
yeti
yeti is on a distinguished road
Water Injection Treatment Flooded my engine.
Hey, so after learning where to inject the water into the engine I decided I'd give it a shot. At first I didn't hole the throttle open enough to keep it running, so I tried again. Then after doing it successfully the idle was wack like it was trying to die then it did and now it won't start. I figured it was flooded so I have changed plugs which they were wet still no go. so I tried the extended method where you inject oil into the housings still no go.. I'm charging the battery now to see if maybe that'll help so the oil will just have to wait until tomorrow. because I have to go to work soon. Hopefully someone can help me if it still doesn't start next time I try.
I still have my apex seals or atleast it was making even whooshes. The car is pointing down hill a bit but I can't roll start it because there is no room. it's an 89 vert.
I think maybe some of the water isn't leaving the engine since it's down hill. but now that I think about it wouldn't leaving the bottom plugs out blow the water around and out?
1989 vert, RB header and presilencer (looking for a catback), SAFC-II, custom fiberglass speakerbox, 130 amp alternator sweetness.
Parts Interchangeability List
yeti is offline   Reply With Quote
