Old 09-15-2008, 11:32 AM   #1
NeuroSpeed
SuperDuper Awesome Member
NeuroSpeed's Avatar
NeuroSpeed is on a distinguished road
ROAR RX-8 Grand Am Koni ST Car
Ok guys, here are some pictures and a little story about how we build our cars. I have been trying to get a camera loaned to me to take more pics but it hasn't happened. As soon as I can get my hands on one I will take more and post them up here.
Our first three cars were bought off the showroom floor, then converted. #61 was a flood car from Katrina. #60 was a car we had that we kept street legal (barely) for quite a while before turning it into a full race car.
Before each car gets a cage, they get completely stripped down to a bare shell. This takes about 2 days with 2-3 guys working on it. Sound deadening and water proofing gunk is taken out. Holes are cut in the tunnel over the fuel tank for the Grand-Am fueling system. Other holes in the car that we won't be needing get filled in - I.E. front firewall hole used to route A/C and Heater lines through.
Tip: Get some dry ice, and use a block of it at a time to freeze the stuff - hit it with a hammer and it shatters and you just pick the stuff up and throw away!
Then every seam in the car gets spot welded for stiffness. After that the cage gets built and put in. Our most recent cage (Cars #61 and #60) allows for a passenger seat since we rent the cars out to new drivers that need in-car instruction.
Then the whole car gets painted. We use Rhino-Liner in the footwells and underside of the car for some sound deadening and good durability.
Pictures at this point:
Also while getting the cage installed the fabricator cuts notches out of the ridge udnerneath the driver's seat so that we can mount the driver's seat super super low using a custom bracket.
While at the fabricators / cage installers shop / paint shop we start getting many of our custom components made (entirely out of aluminum). Water reservoir, pulleys, thermostat housing (just modifications to the stock one), Switch panel for the dashboard, mounting bracket for the AiM Dash, custom Ron Davis radiator, fueling system using a modified stock tank, rear firewall, seat brackets, battery box, our cold air intake, and fire resistant shifter boot. Also our custom front bumper bar, with radiator ducting and oil cooler brackets. And then our carbon fiber headlight replacements. Also, a ballast box gets made that mounts in place of a passenger seat, and allows for the cool suit cooler to be mounted on top of it.
All the parts that we fabricate get a nice coat or two of flat black primer. Any other pieces that we use from the original car such as the brake booster / master cylinder, etc. get cleaned and painted as well.
When we get the car back from the paint shop it is on a stand without any subframes / wheels / etc. We leave it that way for quite a while as we start building it.
Door latches and handles go in. Weatherstripping and rear windows go in. Rear stock bumper goes on and the racing trunk latches go on. The side mirrors go on, and a larger rear view mirror gets mounted to the roll cage. A quick release steering wheel hub gets welded onto the steering column. The pedals for the driver go in along with the brake booster and fluid reservoir, and the dash goes in with the switch panel. A fuse block goes in behind the switch panel but we don't wire anything up yet. The E-brake handle goes in (only used for transport).
We then start working on the fire system, using a SafeCraft fire bottle, and A/N Startlite line. One nozzle for the driver's feet, one for the trunk, and one for the engine bay.
In the engine bay, the ABS unit, Fuse Block, PCM and Battery boxes go in. The custom water reservoir goes in. We mount the CV Products remote oil filter housing that accepts the Fram HP-1 oil filter. The Fuel filter and Fuel pressure sensor are installed in place.
Underneath the car, we start running hard brake lines and fuel line (using the Startlite hose for the fuel line). We also run AiM sensor extension wires for transmission and differential temperature sensors.
We mount up the bumper bar and ducting. We then mount the Setrab oil coolers and run the oil lines.
In the trunk, we mount the dry-break system and run the fuel tubes to the tank. We run the check valve (a valve that allows the tank to breath but closes in case of rollover) line and send it down through the floor. The taillights go in and we run the wires for the taillights and wheel speed sensors. We run the wires through the quarter panel supports and into the cockpit that way, and hide them between the roll cage and rocker panel. The the rear firewall gets installed over the assembled fuel system to protect the driver / passenger should a fire break out in the trunk. We use the stock fuel pump with an auxiliary pump on the passenger side to pump fuel over to the driver's side. Then we attach Startlite hose to it and run it underneath the car up to the engine bay.
At this point the driver's and passenger seats get put in and the seat belts get put in. The passenger's seat and belts may get taken out depending on the next event for the car, however.
The windshield and rear glass get put in whenever the glass company can find the time to come do it (lol).
Around this time we've started running out of things that we can do while the car is on the stand, so we move the chassis over to the lift. Once we do this the differential gets rebuilt with a 512 gearset and Cusco limited slip differential. The rear coilovers (either Koni Spec double adjustable or JIC Single adjustable or JRZ triple adustable, depending on the car's application) are installed. The rear subframe is installed into the car, then the differential, and then all of the rear suspension is built. Half-shafts, hubs, control arms, and brake calipers are all stock. We run stainless steel braided soft brake lines, Racing Brake 2 piece slotted rotors, and Cobalt Friction racing brake pads. At this point the E-brake gets hooked the rest of the way up, and we are done with that end of the car until the very end of the build.
Now it's time for the motor (very sorry I don't have any pics right now!). Our motors are rebuilt at MazMart in Atlanta, and have the ReMedy water pumps which are then machined and matched to each motor for us. They also come with provisions for the A/N line oil system. Our mechanics here are very quick at turning short blocks into long blocks, and have it done in around an hour. Equal-length exhaust headers go on, and then we set the motor onto the sub-frame outside of the car. At this point we bolt up a transmission.
Then the whole assembly goes under the car and the chassis gets set down on top of the subframe. A couple nuts and bolts go in an voila! The car now has a motor! Water lines are then made and installed, and the oil lines are hooked up the rest of the way.
And now for the time consuming part: wiring the car. We begin stripping down the stock wiring harnesses, removing everything we don't need. The engine harness stays the same. The engine bay and under dash harnesses get very stripped though. And we make our own trunk harness (nothing electrical back there but taillights and wheel speed sensors). AiM Sensor wires (for analog inputs; fuel pressure, oil temp, oil pressure) are run into the cockpit and plugged into the AiM dash. Then we put our wiring harness in place and start wrapping it to make it look nice. The PCM goes in. The radiator fan gets put in. And then the Kill Switch solenoid is installed and wired up.
Underneath the dash all the switches (Master [2 of them], Ignition, Start button, Fan, Fuel pump, cool suit, and Wipers) are wired up and the AiM dash is installed and hooked up. Then we install the GPS unit for the AiM, and install wiring and antenna for the radio.
After everything is in the engine bay looks something like this:
NeuroSpeed is offline   Reply With Quote
Old 09-15-2008, 11:33 AM   #2
NeuroSpeed
NeuroSpeed's Avatar
Whew.. 10,000 character limit.
And now only a few things left to do!
Install the slave cylinder and driveshaft. Install the custom made exhaust that we build in-shop. Make sure all the lines are hooked up, and put fluids in everything and bleed the brakes and clutch. Install the Axial Flow short-shifter. Install the transponder. Install the window net and center net.
Start the motor up, make sure there aren't any leaks anywhere. Make sure the AiM dash is recording all the data it needs to. Put the wheels on.
And now we have another race car!
-- Adam
Again, sorry about the lack of pictures for now but I will post up when I can get my grubby hands on a camera.
Old 09-15-2008, 01:12 PM   #3
holy crap, that's a lot of work! How long from start to finish?
How do you like the rx8 platform? How does it compare to your other cars (previous cars?)
Thanks for this awesome thread.
Old 09-15-2008, 01:40 PM   #4
NeuroSpeed
NeuroSpeed's Avatar
Once we get the car back from the paint shop, and as long as we don't have to wait on parts. About 7 12-hour days at a decent pace for 2 1/2 guys. That is, 2 mechanics, and me, the guy that knows enough to do the simple stuff and cosmetic stuff. Lol.
We love the platform. It has it's quirks, like all production cars do. As far as comparing it to other platforms - these were our first race cars. We've done work on mustangs and corvettes and BMW's though, and the only one that got close to being as nice to work on was the BMW.
-- Adam
Old 09-15-2008, 06:32 PM   #5
Very nice thread! You guys sure to good work too in such a tight timespan. I look forward to meeting you all/seeing the cars at VIR!
Quick ? though - I noticed the oil filter mounting location, is that to run a bigger filter or just to make the change out easier during a race? What kind of oil do you all run, and do you use premix? Just curious. I would like to get into that class of racing some day!
Old 09-15-2008, 06:33 PM   #6
Oh - and do you build/customize cages for the public I need door bars....
Old 09-15-2008, 06:52 PM   #7
sumdeus
sumdeus's Avatar
sumdeus is on a distinguished road
Awesome write up!
I look forward to more picture!
sumdeus is offline   Reply With Quote
Old 09-15-2008, 07:07 PM   #8
NeuroSpeed
NeuroSpeed's Avatar
It is both to run the bigger and better filter, as well as to allow us to run the armor braided line. Also, the oil filter housing also gives us ports for both oil pressure and oil temperature sensors. So that little thing gives us many advantages.
We use Red Line 50 wt race oil, which is fully synthetic. We also premix with Red Line Two-Stroke oil to the tune of about 1 ounce per gallon. And we still run the oil metering pump. Trans fluid is a mix of Red Line MT-90 and ATF, while Differential fluid is Red Line 75w90 Gear oil.
For coolant we run distilled water (about 3 gallons worth considering the size of the radiator and coolant reservoir) and 2 bottles of Water Wetter.
As for building the cage, our fabricator just moved to Indianapolis, so we are looking around for a suitable cage builder. Once we find one we will be happy to point you in his direction, although I am sure there are some closer to you.
-- Adam
Old 09-15-2008, 07:30 PM   #9
I've got Mitch Piper close by, which by all means is a reputable cage builder - but I'm always looking for options as he is usually 6 months out booked w/ work...
Thanks for the info, thats the 2nd time I've heard of ATF mix with trans fluid. My jeep mechanic told me the same thing, lol.
Old 09-18-2008, 08:01 PM   #10
Turbo II
Zoom Freaking Zoom
Turbo II's Avatar
I don't see any cup holders Adam.
1988 RX-7 Convertible
1991 RX-7 Turbo
2004 RX-8 GT
1985 RX-7 GSL - Sold
Old 09-18-2008, 09:50 PM   #11
NeuroSpeed
NeuroSpeed's Avatar
We were thinking about putting a kegerator in instead of the ballast box. Then hooking that up to the driver's water line.
Grand-Am wasn't too happy with that idea for some reason.
-- Adam
Old 01-12-2009, 01:43 AM   #12
Flys
Flys is on a distinguished road
Not to bring up the dead but, are you guys using a dry sump system? I can't tell in the pictures.
Flys is offline   Reply With Quote
Old 01-12-2009, 08:04 PM   #13
NeuroSpeed
NeuroSpeed's Avatar
No, we aren't using a dry sump system. We are using the stock oil pan and pump, just with the armor braided lines and remote filter.
-- Adam
Old 01-12-2009, 09:47 PM   #14
How's the team doing?
