Old 09-12-2008, 04:46 PM   #1
Jeff4764
Jeff4764 is on a distinguished road
Ignitors???
I check coils for spark. there wasnt one. not one coil sparked. I guess my question is, do the trailing coils piggy back off the leading coils? Is it possible that the leading ones are just bad? or is it something completely different? If anyone has any ideas let me know please...
Jeff4764 is offline   Reply With Quote
Old 09-13-2008, 10:59 AM   #2
classicauto
crash auto?fix auto
classicauto's Avatar
Check if there is power going to the coils on the harness and go from there.
The leading and trailing coils are entirely seperate, one could fail and the other would continue working.
Old 09-13-2008, 04:55 PM   #3
Jeff4764
well i checked them again today with brand new spark plugs and only got a yellow spark....Is there anything else it could be, I just ordered new coils with ignitors, so if thats now what the problem is I wont be to happy..
Old 09-13-2008, 09:26 PM   #4
Each has it's own ignitor in the base of the coil pack.
Leadings has one.
Trailings has one.
Old 09-14-2008, 01:00 PM   #5
Jeff4764
is it possible that both would go bad at the same time??
Old 09-14-2008, 01:02 PM   #6
very unlucky. you said you were have no tach signal correect? Pop the cap off your CAS and see what things look like.
Old 09-14-2008, 04:54 PM   #7
Jeff4764
no, my tach is working fine, but i checked both sets of coils for a spark and got a very weak yellow spark out of each.
Old 09-15-2008, 02:50 AM   #8
Do you know what the spark looks like normally?
Usually, they look pretty damn weak.
If you'd seen a spark thrown by a CDI box, you'll understand.
Old 09-15-2008, 07:29 AM   #9
Jeff4764
actually no i dont know what they look like normally but there were brand new plugs in the wire and it was only giving a yellow spark.
Old 09-15-2008, 08:57 AM   #10
do you have a "harbor frieght" or similiar store around? What you need are one of those cheapy spark testers that are essentially a light bulb in between a spark plug wire.
Old 09-15-2008, 01:51 PM   #11
Jeff4764
yes there is one about 15 minutes away but theres also a napa autoparts and an autozone 2 minutes away. would they have them there.
