Old 09-12-2008, 04:05 PM   #1
MaczPayne
Bah!
MaczPayne's Avatar
S4 TII & S5 TII fuel rails interchangable?
I've spotted a leak coming from the front side of my upper fuel rail.
Looking for replacements, does it matter if I get an S4 TII or S5 TII upper rail?
I realize the FPR's on both rails are different, but using factory High-imp injectors, would it be possible to use an S4 TII uppers with S5 TII lowers?
Johnson
TA FC in the works!
Old 09-13-2008, 10:58 AM   #2
classicauto
crash auto?fix auto
classicauto's Avatar
FWIW I have S4 TII rails on my S5 TII manifolds....so dimensionally they are exactly the same. EDIT: Actually not quite, I have a couple washers under where the rails bolt on to space them up, otherwise its exactly the same
Old 09-13-2008, 09:25 PM   #3
Primary rails are all the same...dimensionally.
The secondary fuel rails are different.
You can use one with spacers / washers but not vice versa.
