#1 |
Rep Power: 0 ![]() |
I can't get electrical power to my fuel pump. I can hook it up to a separate battery and it works fine.
Any suggestions? |
#2 |
Rep Power: 22 ![]() |
Check the fuses, check your relays.
1976 Mazda Cosmo RX-5 1976 Mazda Cosmo RX-5 2003 Toyota Tundra TRD 2015 Toyota 4Runner SR5 |
#3 |
Rep Power: 18 ![]() |
fuel pump relay is under the dash, like right by the steering column (i think...)
if you cant find it tomorrow, i'll look it up in my FSM.
#4 |
Rep Power: 19 ![]() |
Did you work on the car recently?
Check the "ENGINE" fuse in the driver's side kickpanel. -Ted |
#5 |
Somehow, the fuel pump resistor relay became unplugged.
thanks again. Walt |
| Bookmarks |
