Go Back   Rotary Car Club > Vendors and Group Buys > All Vendors > Re-Speed
Re-Speed www.re-speed.com (GA) Custom rotary parts, specializing in 85-older
Old 09-02-2008, 11:16 AM   #1
Springs / Rates for Coilover kit
i have an 82 FB setup with the GSLSE suspension. Currently i have some adjustable struts and eibach springs, but want to upgrade to the coilover kit you offer.
The only question i have is the spring length and rate. I am assuming that th shorter the spring length the lower the car sits. What is the norm for length? 7 or 8 inch? Then comes the rates, what exactly would you recommend rate wise? I am moving to colorado so the roads are smooth (and fun). The car falls under toy status and generally speaking my tolerances of harshness on the street are pretty high.
I was thinking about the 2.5"x7" in a 425 to 450 rate front (mostly because i plan on running the heavier 13b and possible turbo components in the future) and getting the kit also for the rear and run with a rear 200.
I currently have ST sway bars, stock otherwise. Im figuring camber plates would also be a good upgrade? Would i need them upon install of the above setup?
