Old 08-30-2008, 08:19 PM   #1
-xlr8planet-
-xlr8planet-'s Avatar
My first half bridge :)
I started today. I gave it about 4 hours of work
No work on the bowl or manifold side port ... yet
Im using a dremmel and a small carbide bit. Its all I was able to find
ok, here we go
and this is as far as I was able to go today
Old 08-31-2008, 02:06 AM   #2
damn, I don't know much about porting so I can't really tell if it's good or bad. How far along are you?
Old 08-31-2008, 10:14 AM   #3
-xlr8planet-
its not even close to finished so ... we cant tell now if its good or bad
Old 08-31-2008, 12:49 PM   #4
Rogue_Wulff
Non Member
A dremel is slow, but less chance of making a major error.
I also like the tape covering the area you don't want to hit. Those carbide bits can jump out of the hole, one hit in the wrong spot can ruin the plate. They can jump without warning, even when you have used them for years.
When it comes to porting, getting in a hurry is the fastest way to make mistakes. Take your time, and it should turn out good. Just remember that the entire port area needs to be shaped as smooth as possible to acheive the best flow pattern.
I'm guessing you are planning to street port the center iron, since you say it's a 1/2 bridge. What type of induction are you planning to run?
Old 08-31-2008, 02:39 PM   #5
-xlr8planet-
ITBs
I got a set of cbr600rr itbs. They are 40mm and came with a nice tps and 8 injectors
I already have a megasquirt
Old 08-31-2008, 05:42 PM   #6
Eatmyclutch
business as usual
Eatmyclutch's Avatar
Eatmyclutch is an unknown quantity at this point
Looks like fun.
Bitch
Eatmyclutch is offline   Reply With Quote
Old 08-31-2008, 09:30 PM   #7
Looks good, good shape for now, still probably need to do the backcutting and smooth it out, but should make for some fun!
Go FULL bridge 1/2 bridges are for quitters!
Old 09-01-2008, 03:39 AM   #8
Nutsid
Temporarily insane.
Nutsid's Avatar
I was always curious as to what the difference was between a full bridge and a 1/2 bridge. I didn't realize that the irons weren't port matched before now. I am actually going to begin porting my extra irons as a full bridge soon since they are just laying around and I want the extra practice on porting so that when I get the engine I plan on using as a permanent fixture in my FB (right now a street ported 12A is ready to drop in short of the clutch/flywheel/pressure plate needing to be put on). This was the guinea pig engine to see how well I can get a street ported engine running before doing a TII street port and bigger turbo to swap into my FB.
I can't wait to see the finalized project, Gabriel.
Kindle
Nook
Old 09-01-2008, 09:15 AM   #9
-xlr8planet-
My trip to the states will take a big hit on my savings, but I guess it will be worth every penny.
I think I will finish this engine probably mid next year
Old 09-02-2008, 09:33 PM   #10
-xlr8planet-
I worked a lot today
Old 09-25-2008, 11:39 AM   #11
diabolical1
I have radioactive semen
are you planning on turbocharging later on down the road? just curious as to why you decided on a half bridge instead of full.
all in all it looks like it's all coming together. let me echo the sentiment that you should take your time. it's best to make sure it's done right as opposed to just "done".
Old 09-25-2008, 01:00 PM   #12
-xlr8planet-
I wont go turbo later on.
I plan on cracking open this engine at least a couple of times, so if I see fit going full bridge later on .... hehehe I will.
I will stay with the h bridge + 100shot of NOS for now.
Old 09-27-2008, 09:34 AM   #13
jtbshaw
ORD - Old Rotary Dude
jtbshaw's Avatar
On my last 1st gen, i ran the same setup that you are going with....1/2 bridge and 100 shot. The 150 shot was insane. I also planned to go turbo, but couldn't come off of the spray. You can read more about my old setup here: http://www.cardomain.com/ride/852654. Looks good so far, I'm sure that you will have a blast with it when you are finished.
Todd B.
Old 09-27-2008, 09:29 PM   #14
-xlr8planet-
Todd B.
Opening link right now
Old 10-17-2008, 03:24 PM   #15
BigTeddy
BigTeddy is on a distinguished road
One Turbo At A Time
BigTeddy is offline   Reply With Quote
