Old 02-29-2008, 10:54 AM   #1
ppritchard
ppritchard's Avatar
Low Secondary Boost -- How did you fix it?
I know that plenty of FD owners have encountered low to no boost from the second turbo. And I've read the troubleshooting guides that are really quite well done.
What I am wondering though is Exactly what you found/fixed to correct a low boost from the Secondary.
Really interested in getting a feel for the frequency of the different problems that cause the boost issue.
Thanks
Old 03-01-2008, 12:49 PM   #2
A Damn Pitt
A Damn Pitt is on a distinguished road
Umm typically you need to rebuild or replace your secondary turbo. especially if it was boosting fine but over time dropped.
A Damn Pitt is offline   Reply With Quote
Old 03-03-2008, 09:25 AM   #3
SPICcnmFD
SPICcnmFD's Avatar
I real good sign of needing a rebuild, due to a bad secondary, is if it his full boost after transition but drops off more and more as the rpms rise.
Old 03-04-2008, 01:01 AM   #4
Bryan@BNR
Bryan@BNR is on a distinguished road
Check bypass valve on secondary side, it could be blowing open.
If engine has been blown, the bits could have ruined the turbine wheel in the 2nd turbo.
It could be a leaky diaphram in the switching actuator in the exhaust manifold or leaks in the vacume lines going to them.
It could be bad bearings in the turbocharger as Chris stated.
Bryan@BNR
Bryan@BNR is offline   Reply With Quote
Old 03-05-2008, 10:23 AM   #5
ppritchard
ppritchard's Avatar
Thanks
