Old 08-18-2008, 11:46 AM   #1
Darren
Darren is on a distinguished road
Removing Rear tailights
Can someone tell me how to remove real taillight assembly. Repainting the car. Can't seem to figure this out. Thanks
Darren is offline   Reply With Quote
Old 08-18-2008, 12:37 PM   #2
lt1_fd3s
WNC Tour Guide
lt1_fd3s's Avatar
open hatch
unscrew the philips head screws holding down little black plastic parts..(3 on each side light, 4 for middle light)
remove plastics
unbolt 10mm bolts (2 on sides, 3 or 4 for center...)
lift up center light, disconnect wires.
grasp the side lights, pull towards the outside of the car. the little clips should eventually let the lights pop out....
make sure you twist and remove bulbs before walking to far from the car with side tail lights in hand...
hope that helps
Old 08-20-2008, 12:34 AM   #3
dregg100
just to clairify, the outside lights dont have any bolts, just the screws and they pop off. the center light is the only one bolted on.
'93 SSM Touring-S475...
'87 Tii-LS1/T56
Old 10-23-2008, 09:25 AM   #4
MX3
MX3 is on a distinguished road
I just removed mine this past Sunday. The mid section was no problem at all.
The side ones you have to be gentle with a bit.
After you've removed the screws you have to push it inwards towards the center.
Really, its not that difficult.
Havent put them back yet. I wonder if that is going to be difficult.
MX3 is offline   Reply With Quote
Old 10-23-2008, 09:34 AM   #5
Nexcis
Nexcis's Avatar
Nexcis is on a distinguished road
Putting then back in is just as easy as it is to remove... just in reverse order.
'94 VR FD - Mod List
Nexcis is offline   Reply With Quote
