Old 08-02-2008, 11:30 PM   #1
AHarada
Rear oil pipe on stock twins
I'm having trouble getting this pipe on. It's the pipe with the heatshield over it that goes from the secondary turbo to the rear iron. When I took it off, it came off with no problems, but now for some reason it seems like it's bent. Anyone experience this? It's almost as if I am missing something in between the iron and the pipe, but I don't think I am. I have 2 of them and both are the same.
Old 08-03-2008, 08:36 AM   #2
dregg100
so, the drain line? just bend it a little.
'93 SSM Touring-S475...
'87 Tii-LS1/T56
Old 08-03-2008, 09:45 AM   #3
David Jerome
David Jerome's Avatar
You have to force it on there, those oil drain lines get bent really easily. Ther rear one doesnt bend as easy as the front but it is often times difficult to get to line back up. Worse case scenario you loosen all the turbo bolts/nuts to provide some extra clearance.
David
David Jerome
Old 08-03-2008, 11:20 AM   #4
tom93r1
tom93r1 is on a distinguished road
loosen the piece thats attached to the turbos as well, it may provide enough slack to get everything back together.
74 REPU big port 13b Weber 48 DCO
93 RX7 R1
76 Suzuki RE5
tom93r1 is offline   Reply With Quote
Old 08-04-2008, 08:24 AM   #5
SPICcnmFD
SPICcnmFD's Avatar
Like DJ said loosen the turbos up so they can move around then put the oil pipes on and then tighten the turbos down.
1993 Rx-7 SM2 #11
At the local AutoX:
Speed for Sale shootout 2007:
A few laps at Barbers:
