Old 08-02-2008, 01:11 PM   #1
Front races question
I'm putting my new races in and ran into a problem. While pressing/hammering them in, the larger set (inner?) get down to about 1 mm from meeting the surface and won't go any farther. I've tried hammering with a 2.5 lb sledge hammer and using my c-clamp press to no avail. It won't budge.
Is the gap supposed to be there?
I, for the life of me, can't remember it being there yet it seems to need to be. Any help would be super appreciated. This 1 week "replace my bushings job" has turned into a 2+ month ordeal. I'm about ready to just fucking throw every damn piece across the field.
Old 08-07-2008, 02:17 PM   #2
wvumtnbkr
wvumtnbkr's Avatar
wvumtnbkr is on a distinguished road
I work with tapered roller bearings alot in my line of work, and have never seen a "GAP" that was supposed to be there!
If you are using a tapered roller bearing, it means that there is high "side loading". This is trying to push the outer race against an immovable object (hub). In order for the bearing to support this load, it must have full contact with the immovable object (hub). If it does not, it will warp and destroy the outer race.
Remove the race, and clean up anything underneath it.
That being said, I have never done this to an FC, soooo I could be way off base (it would be very strange indeed!).
wvumtnbkr is offline   Reply With Quote
Old 08-07-2008, 07:27 PM   #3
josh18_2k
i'm gonna guess that there is a burr in there.
you're supposed to clean and deburr the area before pressing in new races.
Old 08-07-2008, 07:36 PM   #4
BLKTOPTRVL
BLKTOPTRVL's Avatar
Doesn't look like a big gap but... If the racetrack (pun) is clean and there are no burrs.
Stick it in a plastic garbage bag and pop it into the freezer on a level plane overnight. Next morning, if it has not dropped into place, then press it while it is still cold.
I did this years ago when I did not have a press and all the bearings I seated fell right into place.
Old 08-08-2008, 06:42 AM   #5
Update: I took them to get pressed in at a shop. Very very little change. They even took a couple out and looked and there were no burrs. I'm not sure what's wrong, but are they usable like that? The picture there is the largest gap. The others are smaller.
Old 08-08-2008, 11:11 AM   #6
classicauto
crash auto?fix auto
classicauto's Avatar
gap shouldn't be there, somethings up. I dunno what to say....
Every time I've done I've used the welding on bolts method and when I put the new races in the hubs were still warm (and thus, probably expanded a bit being aluminum) and they've always seated where the original ones went.
but if there's nothing in the way like burs, dirt or anything else then it'll probably be fine. I'd heat them up and set the old races on top and give it a few smacks though just to be sure.
Old 08-08-2008, 12:38 PM   #7
It did it even heated. They put them in when the hub had been torched by a giant propane torch (me want...).
Just to clarify, would you use them as is?
Old 08-08-2008, 03:16 PM   #8
classicauto
crash auto?fix auto
If its bottom'd out as far as it'll go..........yup.
I'd probably assembly the hub/spindle and check for any werid play and good free movement, but I'd run those babies.
Old 08-08-2008, 04:58 PM   #9
misterstyx69
.drives like MrMagoo!
misterstyx69's Avatar
I think Aaron Cake had a bit of info,But it is on the other forum(sorry,I should be Flogged!).. I do believe he had a method of getting the Races in.Personally I would ALSO use them.the only Thing that I THINK would be of concern is the Gap wearing a Slit into the Needle bearings(wheel bearing).If you have lubed the Bearing Good,then this shouldn't Happen for awhile.
Old 08-08-2008, 11:21 PM   #10
I was going to suggest cleaning it, then putting the hub in the oven, and the race in the freezer, then Use some stuff like PB Blaster for lube and it should pop right in.
Also, did you check the race itself??? Maybe get some 600 grit emery cloth and sand it a little???
Old 08-09-2008, 06:20 PM   #11
The machine shop used a hydraulic press after heating the hubs to the point where the race I had put in just fell out the bottom. Also, it's all 4 races. I think it has something to do with my method of putting them in (sledge hammer...) or something. Regardless, I'm going to put them on tomorrow and hopefully drive my car for the first time this summer.
Old 08-11-2008, 07:41 AM   #12
Boostmaniac
Good luck man, I don't like how that looks personally. Keep us updated.
FWIW, never use a hammer on anything that needs to be pressed in, this will cause warpage or an angled load. There is no real way to even out the pressure without using a press.
Old 08-12-2008, 07:04 AM   #13
Yeah...
Now I need a spring scale and can't find one locally. I wonder if there's a trick to preloading the bearings without one of those.
Old 08-12-2008, 05:15 PM   #14
josh18_2k
i just torqued them to 22lb-ft. the FSM says to do that, then back off, then do the spring test, but screw all that. as long as you can spin the hubs by hand, its fine. you're not gonna overtighten them. the spring test is just to make sure the wheel spins freely. if you want it to spin easier, loosen it a little. i'd rather err on teh tight side then have any slop and ruin the bearing.
