Old 07-26-2008, 11:58 PM   #1
ROTOSPEED
ROTOSPEED is on a distinguished road
help picking a clutch
im turboing my 85 12a and i need to pick a clutch that will last. its for street driving and maby some track use.
are the F1 clutches eney good? i've seen one kit that has a light flywheel.
ROTOSPEED is offline   Reply With Quote
Old 07-27-2008, 03:07 AM   #2
TheDriver216
TheDriver216's Avatar
i would say centerforce duel friction clutch would be good.. but that will also depend on your horse power goals.
Old 07-27-2008, 05:08 PM   #3
ROTOSPEED
i think i should be about 150-175 hp and 200-230hp when i build a new engine next year.
ill loock into the centerforce thanks.
Old 07-27-2008, 07:08 PM   #4
PercentSevenC
Custom User Title
PercentSevenC's Avatar
I've been using the Racing Beat heavy-duty clutch disc with an 8 lb. flywheel and stock pressure plate (would've preferred an RB street/strip pressure plate, but I didn't have one handy at the time). It's very easy to drive and grabs pretty well.
Old 07-28-2008, 03:51 AM   #5
Kentetsu
Kentetsu's Avatar
Check with www.re-speed.com
They know what works...
Old 07-28-2008, 06:43 AM   #6
JL1RX7
For what is worth I have heard good things about spec clutches.
Old 07-29-2008, 11:48 AM   #7
Jeff20B
Jeff20B's Avatar
9 pound aluminum flywheel, HD disc, street strip pressure plate. This setup takes me a few seconds to get used to it if I've driven something else recently. It feels like a light steel in weight because there is a Camden on the engine. The disc is grabby but also very easy to drive. The extra effort of the SS pressure plate is what takes a few seconds to get used to.
Old 07-29-2008, 10:11 PM   #8
ROTOSPEED
im thinking about a sprung 4 puck disk and a street strip plate. if i do i dont think ill have the $$$ to change the flywheel at this time.
Old 08-10-2008, 01:57 PM   #9
Jeff20B
Jeff20B's Avatar
You probably won't like to drive it in bumper to bumper traffic. Fortunately your stock flywheel will take some of the abruptness out of it, making street driving possible. It's till gonna suck though... maybe.
You might try to look for a 6 puck. They're more streetable and still have high clamping force for the big boost numbers you're going to run.
