Old 07-26-2008, 05:06 PM   #1
Riot
Riot is on a distinguished road
Need help with GT35R install...please!
New to the forum & single turbos, but looking for help on some specifics about hooking up the coolant fittings I received with my GT35R kit. The fittings I got for the CHRA coolant inlet/outlet have an o-ring & washer (see pic). Now the CHRA doesn't have a seat per say for the o-ring, but it does have a small chamfer. I am assuming that I need to use both the o-ring and washer, and the washer just helps with keeping the o-ring from squeezing out while torquing the fitting down. Am I correct?
The problem I have with this is that the o-ring doesn't really fit inside the washer, and I don't know how I would torque this down without pinching and ruining the o-ring. Also this fitting is made by Parker---and while I know they do a lot of things for hydraulics, I'm not to sure about automotive---I wonder if the o-ring supplied can even take the temperature that the CHRA will see.
Any help or advice that anyone can offer would be greatly appreciated.
Riot is offline   Reply With Quote
Old 07-26-2008, 06:19 PM   #2
Mobius
Rotorhead
It's either or, not both. In this case, I would use the crush washer, as I would also have doubts as to if the o-ring will withstand the heat.
Old 07-26-2008, 06:25 PM   #3
Riot
Thanks. Should I get an actual copper crush washer then? The washer supplied is zinc plated steel....
Old 07-26-2008, 08:02 PM   #4
Mobius
Rotorhead
You could if you want, but I would assume the one they included would work fine?
Old 07-26-2008, 08:13 PM   #5
Riot
I could use the washer that was supplied with the fitting....but it's obvious this fitting isn't made specifically for turbos and I'm worried about how well it's going to seal. Really trying to avoid having to tear the car apart again to fix a leaky connection.....
Old 07-31-2008, 06:40 PM   #6
cewrx7r1
The Judge
Copper or aluminum crush washers are best. Mazda uses both types on their engines.
Old 08-02-2008, 10:06 PM   #7
Riot
That's the confirmation I was looking for. Thanks!!
Old 08-05-2008, 11:33 PM   #8
GorillaRE
Outside the "box"......
GorillaRE's Avatar
Does the "Oring" you have fit the inside diameter of the washer?
-J
Old 08-06-2008, 07:45 AM   #9
Mobius
Rotorhead
-J
Old 08-06-2008, 07:28 PM   #10
Dr-Rotor
Dr-Rotor's Avatar
Dr-Rotor is on a distinguished road
Be sure to post your power figure when its all tuned.
Dr-Rotor is offline   Reply With Quote
Old 08-06-2008, 08:21 PM   #11
Riot
-J
It's close but not really---after looking at some of the fittings at ATP turbo I was confused as it looks like the ones they sell have a rubber or viton seal as well. I ordered some copper crush washers---we'll see how they work.
Old 08-06-2008, 08:24 PM   #12
Riot
Will do....not going for huge horsepower but expecting to top out somewhere between 375-400 rwhp. Street ported motor, GT35R with 0.84 A/R hotside, and all supporting mods.
Old 08-06-2008, 08:35 PM   #13
Dr-Rotor
Dr-Rotor's Avatar
Cool...post it in my new thread for this turbo please...cheers.
Old 08-16-2008, 01:09 PM   #14
JDK
I Yam What I Yam
JDK's Avatar
JDK is on a distinguished road
Which kit did you use? And which flange T 3or4
JDK is offline   Reply With Quote
Old 08-21-2008, 09:54 AM   #15
Riot
A-Spec...medium runner, divided T4, v-banded, wastegate dump plumbed to downpipe, ceramic coated---overall I'd have to say a pretty nice kit.
