Old 07-17-2008, 01:18 AM   #1
EDIT: Brake Troubles.
Ok, so I am in the middle of putting my vert back on the road, and ran across an issue with picking up a brake master cylinder.
For some reason, my 1991 car came with an S4 master cylinder, which leaked all over the place and went to shit, and most places like auto zone only carry ones that come without the reservoir.
I found some on ebay, but they are either also S4, or come for cars with adjustable suspension or abs. Adj suspension: i dunno if I should worry about it, but I know ABS cars are different somehow.
Here's a few that I am considering:
http://cgi.ebay.com/ebaymotors/Brake...spagenameZWD1V
http://www.autopartswarehouse.com/de...dot-45105.html
http://cgi.ebay.com/ebaymotors/ws/eB...157146426&rd=1
What do you think? The Centric one looks weird, but I think that that's a "stock" photo of it. The first one is the one for adjustable suspension btw, doesnt look that different. Also, are the turbo and N/A ones different? I read that they are.
Old 07-17-2008, 01:28 AM   #2
I have an S5 TII one in storage somewhere. If they're the same I can send it to you, just pay the shipping and paypal fees. I don't think it's too used but i can take pics if they're the same. Let me take a look at the FSM.
Old 07-17-2008, 01:14 PM   #3
TehMonkay
aas master cylinders have a threaded port with a sensor that goes in it to determine braking pressure to adjust the suspension.
Old 07-17-2008, 02:14 PM   #4
Boostmaniac
Straight from Mazdatrix.
http://www.mazdatrix.com/getprice.as...m=43-400D-FB02
Apparently, all master cylinders on non turbo, non AAS cars are all the same from 86 - 91.
Remember that Mazdatrix is the answer to a LOT of questions when searching for parts.
Old 07-17-2008, 02:53 PM   #5
Well, since the vert comes with 4 pot brakes, (no abs, and without the adj. suspension) it should be the same as a turbo one so I would love that. Also, what are these "paypal fees" you are talking about, phoenix? I have a premier account (seller and buyer) and never had to pay these yet...)
Also, my driver's side front caliper has gone bad! I tried to open the bleed valve, and it just snapped off! Luckily it was a section without the check valve, but now the caliper is useless. since my car has 140K on it, and I'm shure these are way gone anyway, should I just get some new ones from autozone? They are on sale for $88 each if you give them a core, and I think you can buy a pair as well for cheaper.
third question: SS brake lines. Should I get just the $89 corksort lines or are the goodridge g stop ones better? I dont care about DOT approved, just that they dont fall apart.
http://cgi.ebay.com/ebaymotors/Stain...mZ380044366310
http://shop.ebay.com/?_from=R40&_trk...All-Categories
EDIT: Thanks for clearing that up, boost! But still, if you have 4 pot brakes with vented rears on your NA, wouldnt the turbo MC be the same as well because the brake system is the same?
Old 07-18-2008, 07:46 PM   #6
woops...double post.
Old 07-18-2008, 07:53 PM   #7
I would have to say that is not accurate. I have had two S5 GXL's with AAS and neither have that sensor.
AAS equipped S5's all have the 4 pistons calipers, so they are the same MC as the TII's and Verts.
Her ya go:
Beck/Arnley item #072-8430 www.beckcatalog.com
Get one and you are supporting yours truly!
Old 07-18-2008, 08:46 PM   #8
so i will probably just get phoenix's one or get the beck then. I used their thermostat, and it passed the boiling water test just fine!
