Old 07-08-2008, 12:45 PM   #1
FD water pump housing on 12A engine...
Does anyone know if FD water pump housing will fit on 12A with FD pins?? I have 12A in my RX2 and bunch of FD parts. If I could use the FD housing on the 12A, I could even put the FD alternator.
I had a belt break on me and the 12A over heated. Engine is fine but Don't want that happening again...
If Any of you know this, I would greatly appreciate it, before I take mine apart..
Old 07-08-2008, 12:51 PM   #2
i pmed you
Old 07-08-2008, 02:29 PM   #3
Kentetsu
Kentetsu's Avatar
I did a 2nd gen housing, but haven't heard of anyone doing a 3rd gen yet. Good luck, and take some pics if you do it.
Old 07-10-2008, 11:17 AM   #4
Jeff20B
Jeff20B's Avatar
The pullies are different so you might need to swap your other pullies over to FD.
Old 07-11-2008, 06:59 PM   #5
djjjr42
djjjr42's Avatar
djjjr42 is on a distinguished road
Originally Posted by Low Impedance View Post
i pmed you
If you know the answer would you please post it in the thread so everyone can share in the knowledge?
'83 GS, Misty Blue, 45k miles: RB SP Exhaust, Springs, & Front Sway, Weber DCOE, etc.
'83 S, Black, 127k miles: Current Project, Stock (for now)
djjjr42 is offline   Reply With Quote
Old 07-12-2008, 11:54 AM   #6
well i have never used an FD pump on a 12a, BUT i have used an FC housing on a 12a with the 12a pump. That connected right together without any issues. Being that i used a 13b housing on a 12a, i can't see why the FD pump assembly wont work. The only issue i had was created but using the aluminum 12a pump with the aluminum 13b housing. The alternator mount portion doesn't line up to give you a place to connect the tension bracket
what i did instead was pull one of the studs out after mounting and used a long bolt instead. Then i modified an air pump bracket to work.
