Old 07-08-2008, 07:40 AM   #1
N.RotaryTech
Home-brew Rotary
N.RotaryTech's Avatar
Gas mileage, what you getting?
In my '89 GTU, (S5 mild port n/a, with RB mufflers an presilencer, emission's removed, AC components removed, aux sleeves an actuating rods removed, vdi open, heat-shielded cone air filter, 1/2oz. per gallon premix.) usually the range is from 18-25 MPG.
But with the latest tank, I got 27.6 MPG! Which is the highest I experienced in this car.
On a regular day, the breakdown is probably...
With city driving, I get about 18-20 mpg.
Hwy & city, I get 20-22 mpg.
Out of town RX7 meet or out of town trip, I get 22-25 mpg.
But the latest tank I did, out of town trip, and hwy & city driving.
Averaging 70 mph on the hwy.
And got 27.6 mpg.
Someday...30mpg...someday.
'87 RX7 GXL, Rest In Pieces.
'94 Ford Ranger, daily.
Old 07-08-2008, 11:47 AM   #2
I'm getting 18-20mpg city (15mpg on good days) and up to 25 hwy.
Intake, RB header, midpipe and HKS 52mm catback. Pineapple Aux. sleeves, SAFC (tuned to 11's = ~ 150rwhp), no premix, Avg 75mph.
Good numbers BTW. 30 MPG seems doable.
Old 07-08-2008, 12:02 PM   #3
I'll post up my stats once I'm back on my home comp.
Old 07-08-2008, 02:12 PM   #4
Right about 14 - 15mpg strictly city driving...
It'll creep up to about 17 - 18mpg once I start jumping on the freeway more.
13BT
ported
stock turbo
stock IC
11 - 12psi
Haltech E8
240hp at the wheels on a Dyna Pack
Old 07-08-2008, 03:08 PM   #5
I stopped keeping track a few fill ups ago, but before then...
Date : Gallons (mpg)
5-07 : 9.241
5-18: 10.656 (17.6426)
5-25 : 9.501 (20.1031)
6-05 : 11.754 (18.4618)
6-25 : 11.030 (15.9565)
7-15 : 8.806 (14.3084)
7-31 : 11.516 (15.4567)
8-08 : 6.922 (16.4692)
8-11 : 2.808 (17.094)
8-12 : 4.707 (24.4317, all highway for a test)
8-25 : 10.294 (16.4173)
9-01 : 11.080 (19.0433)
9-10 : 10.928 (19.5827)
9-19 : 5.603 (13.03)
9-28 : 12.584 (17.244)
10-12: 10.604 (17.9178)
10-22: 10.342 (18.3717)
10-31: 10.603 (17.3536)
11-10: 10.301 (19.1246)
11-20: 10.685 (19.905)
12-14: 10.493 (15.0103)
1-05 : 11.228 (11.7549)
1-13 : 7.912 (25.63)
1-30 : 9.124 (15.7825)
2-21 : 9.529 (15.1117)
3-03 : 10.598 (20.664)
Average mpg : 16.9949
That's probably 65% city. S4 N/A with wired open 5/6th ports (haven't got around to fixing that).
Old 07-08-2008, 04:56 PM   #6
Here's my MPG from 12/07-6/08
10.84969789
11.08811354
22.46897453
20.78227049
24.25531915
21.83933766
23.01381693
11.44400786
10.89867579
21.60533911
22.88592867
14.04095422
14.97948527
23.05433732
18.46236312
23.56626861
24.09230769
21.86765989
24.55517241
22.7091272
23.39853301
22.44504111
23.33252876
23.8468854
24.26514697
20.70511886
Old 07-09-2008, 12:37 AM   #7
MaczPayne
Bah!
MaczPayne's Avatar
I get about 18mpg combined, 22 on the highway.
s5 13bt + stock turbo
12psi + stock IC
RB turboback
MT LT8-s
~230whp
Johnson
TA FC in the works!
Old 07-09-2008, 03:17 PM   #8
classicauto
crash auto?fix auto
classicauto's Avatar
all hwy driving without opening the secondaries I can get slightly over 20mpg (roughly...I'm converting from Km's) but when I'm denting the floor with the loud pedal its closer to 10 But it (was) fast as a scared monkey.
Old 07-09-2008, 05:25 PM   #9
FirstRotaryExp
Avg'ing right around 20-24mpg on a stock block with out emissions running a RB header/presilencer and a straight pipe into a cheap ebay muffler, SAFC with about 10% fuel knocked out at idle to -4% at redline(still need too actually tune it better), an intake leak of some kind, either a gasket or one of the lower injector grommets, no ac/ps. And average MPH is 80+ during interstate travels and 60ish around town. 1-2 gear is always redlined before a shift, and sometimes 3rd as well. But i hope to better my numbers soon with a better CAI, instead of the cone on the end of the intake tube in the hot bay. Car also has an FD alternator an a ford escort Efan. Still need to get around to getting a cleaned/flow tested set of injectors installed and tidying up things but its driven everywhere I want it to go.
Old 07-20-2008, 08:12 PM   #10
88turboii
destroy, rebuild, repeat
88turboii's Avatar
And got 27.6 mpg.
I call BS, brother.. i bet the gas pump was not calibrated right. the best ive seen is 24.5 which was mostly crusing at 60mph, i usually get 16 mpg city. rtek 2.1
Old 07-20-2008, 09:05 PM   #11
I believe 27.6 all highway. I get 24 mpg all highway and that's on an untuned N/A. A good tuning on a TII that stays out of boost can hit that. Now whether or not he actually got it, who knows. But I say it's possible.
Old 07-21-2008, 07:05 AM   #12
I do not dive mine enough to keep track that well, but on the way back from DGRR, I averaged 28.5 MPG.
S5 TII, no emissions, RB DP & silencer, Apexi N1 EVO catback.
Old 07-21-2008, 11:54 AM   #13
BLKTOPTRVL
BLKTOPTRVL's Avatar
I've gotten 26-27 in all hw driving in my vert. It is possible.
Old 07-23-2008, 05:28 PM   #14
I've gotten calculated 28mpg, and it should've been more like 30mpg cause I didn't drain the gas tank all the way down.
The trip OD hit 400, and typically fill-ups were about 13 gallons - you do the math.
Since I was doing such long distance driving, I wasn't going to take a chance and drain the gas tank that low - i.e. the fuel-low warning light never came on.
If I really wanted to push it, the car would've easily hit 30mpg.
This is driving between Sacramento, CA and Las Vegas, NV 100% freeway at speeds of 60mph to 80mph, just under the point where the secondaries kick in at 3,500RPM.
Back then it was stock ECU (well, reprogrammed G-Force unit) with full exhaust on a 1987 Turbo II.
Side note, I was able to hit 200 miles on a 10 gallon fill-up's.
I only fill up 10 gallons at a time, and it makes calculating mileage easy now.
Still tweaking the Haltech E8...
Old 07-23-2008, 05:33 PM   #15
fellas, hook me up in this thread:
http://rotarycarclub.com/showthread.php?p=35564
