Go Back   Rotary Car Club > Vendors and Group Buys > All Vendors > BNR Turbos
BNR Turbos www.bnrturbos.com (AL) Custom and rebuilt turbochargers
Old 07-02-2008, 02:35 PM   #1
My stock turbo is kaput
my current daily driver, a 1987 Turbo II, has decided that the oil running to the turbo is no longer need to be contained and now throws it where ever it wants, including all over the compressor housing.
So im looking into the BNR rebuild, but not really sure where i want to go with it. Once i take the car off daily driver duties, ill be using it as a weekender/fun car and registering it with collectors plate so emissions will not be a concern.
Being that i usually try to plan ahead on things, i will be eventually running a streetported engine once the current one is tired.
I was thinking about just going with the "stage 4" and call it a day, but i would like to get some insight from the man himself.
Old 07-03-2008, 10:35 AM   #2
Bryan@BNR
Bryan@BNR is on a distinguished road
The man himself! Don't try and make my head inflate .
Alright, what I need to know is how much boost and RWHP you are aiming for... From there i will see which one meets your needs. If the power is more than a hybrid can give, I will just point you in the right direction.
Bryan@BNR
205 640 1193
Bryan@BNR is offline   Reply With Quote
Old 07-03-2008, 10:54 AM   #3
id be happy with 300 at the wheels. more than that is just bonus. i would like to see full boost by 3500
Old 07-06-2008, 10:41 PM   #4
Bryan@BNR
Stage 1 or 2 will reach your goals.
Bryan@BNR
Old 07-11-2008, 03:35 PM   #5
CarbonFD
CarbonFD is on a distinguished road
What are the specifics on the Stage 4 that was mentioned above and what do they differ from on the stage 3.
Chris
CarbonFD is offline   Reply With Quote
Old 07-13-2008, 10:04 PM   #6
Bryan@BNR
Chris
Hey Chris.
The Stage 4 has a P trim turbine wheel and the factory turbine housing is machined to fit that P trim T4 turbine wheel. The Stage 4 is a full T4 turbocharger that is fitted to the stock turbine housing.
The stage 3 is a clipped stock turbine wheel which hits restriction at around 350 RWHP depending on how far you clip it. P trim can give you 30-50 RWHP gains with the right set up!
Bryan@BNR
205 640 1193
Old 07-15-2008, 02:11 AM   #7
CarbonFD
Is this the same for the stage 3 for the FD? Sorry I didnt mention that before. IM shoting for 400+.
Chris
Old 07-15-2008, 01:54 PM   #8
Bryan@BNR
Chris
The FD stage 3's are not anything like the S4 or S5 RX7's. The twins smaller frame turbochargers that have made over 400 RWHP on many cars and some up to around 425 RWHP.
Old 07-15-2008, 02:51 PM   #9
CarbonFD
OK so there is no stage 4 for FD then correct... Thanks Bryan and I plan on doin you proud with the BNR's... Shooting for 430+ Seq. cross your fingers...
Chris
Old 07-17-2008, 12:29 AM   #10
Bryan@BNR
Chris
Sweet! Just let me know when you are ready...
Bryan@BNR
Old 10-01-2008, 08:02 PM   #11
ArtsRx7
ArtsRx7 is on a distinguished road
What is the turn around time on a upgrade/rebuild/
ArtsRx7 is offline   Reply With Quote
Old 10-01-2008, 09:42 PM   #12
Bryan@BNR
3-4 weeks turn around.
