Old 06-28-2008, 04:46 PM   #1
buddyboy555
buddyboy555 is on a distinguished road
Question gas flooded engine.
How do I evacuate a badly flooded engine of gas?
buddyboy555 is offline   Reply With Quote
Old 06-28-2008, 05:11 PM   #2
please be as detailed as possible when making threads. I'm going to ask a MOD to merge both your threads into one.
Flooding:
On a series 4 you have to remove the EGI. INJ. fuse in the engine bay.
On a series 5 you pull the EGI. fuse
Get back in the car with the fuse in your hand. Cranck the motor for 10 seconds. Repeat up to 3 times. If it's mildly flooded then your car should start when you put the fuse back in it's place.
Old 06-29-2008, 07:38 AM   #3
buddyboy555
I don't understand series 4 or series 5. The car is a 1988 rx7 convertible
Old 06-29-2008, 12:49 PM   #4
ok, well first things first. Read and download the manuals here
http://www.rotarycarclub.com/showthread.php?t=1790
basics:
1986 to 1988 FCs = Series 4 (series 1, 2 and 3 were first generation 1979-1985)
1989 to 1992 FCs = Series 5 (series 6, 7 and 8 were third generation 1992-2002)
reasons for flooding:
-bad/leaky injectors
-low compression
-you turned the car on and then off before it was able to complete the warm-up procedure.
Take a video or be super detailed otherwise we're all working blindly. The "foot all the way down" is also a Mazda aid to help you deflood so you're doing ok. Just keep working on the details.
