Old 06-20-2008, 01:41 PM   #1
Front lower arm bushing question... P.S. I hate them
I finally got around to removing the bushings on my front lower arm. After about 1.5 hours and some smushed fingers, I got both of the bushings off that slide on and can't be pressed out. Anywho, I managed to slightly damage the shaft (likely from my chisel.....) during taking them off.
Is this damage alright?
Should I grind it down and make it smooth/not a V-shape?
Old 06-21-2008, 08:01 PM   #2
jgrewe
It'll be fine, just smooth it out so you can get the new one on.
Old 06-22-2008, 07:33 PM   #3
Also, are there only 8 bushings up front?
2 per lower arm
2 per control link
Old 06-26-2008, 11:23 AM   #4
classicauto
crash auto?fix auto
classicauto's Avatar
yep 8 in total.
Old 06-26-2008, 03:38 PM   #5
Now I'm at a standstill. It says that some Endlinks need the 2305 bushing and some need 2300... yet it gives no way to discern which to use.
Old 06-26-2008, 03:50 PM   #6
classicauto
crash auto?fix auto
IIRC some of the endlink bushings are slightly larger then others. You'll be able to tell because when you go to push them into the endlinks when they're lubed up, they'll slide back out if they're too large..........at least thats what I ran into.
Old 06-26-2008, 08:17 PM   #7
I went back to check this out after I made my first post out of frustration. The two options are very different so it's hopefully going to be pretty obvious which will fit (then again, it's me....).
Old 06-27-2008, 12:19 AM   #8
Finding this is always fun. Raise your hand if you can spot the problem...
And now for some positives... Pic 1: Old and busted. Pic 2: New hotness.
I had already chewed the large bushing up a bit so ignore that damage. Otherwise, the first pic shows it how it was when I took it off the car.
Old 06-27-2008, 01:02 AM   #9
TehMonkay
you need new brake pads
Old 06-27-2008, 09:39 AM   #10
I have some HPSs waiting for me and new calipers. I'm going tomorrow to get new rotors so the whole front system will be new.
Old 06-28-2008, 11:12 AM   #11
classicauto
crash auto?fix auto
Lookin' good Rob. Am I going to get a spin down the dragon in '09???
Old 06-28-2008, 02:53 PM   #12
If all goes well, then yes. I just hope you can handle the ridiculous G forces the N/A is going to put out during acceleration.
