Old 06-16-2008, 09:10 PM   #1
KaiFD3S
KaiFD3S's Avatar
Guess this symptom...
I am puzzled if my clutch is going, here is what is going on 1st, 2nd and 3rd are fine no slippng but while I am in fourth and start to build boost then go WOT it will slip for a second then grip...
What I am wondering is that I can do a burn out without slippage or punch it in 1st second or third but in fourth gear it slips for a second..
Wise people let me know..
Thanks in advance
Kai
RE AD FACER 9
Old 06-16-2008, 10:48 PM   #2
tom93r1
tom93r1 is on a distinguished road
You need a new clutch disk
tom93r1 is offline   Reply With Quote
Old 06-17-2008, 06:57 AM   #3
SPICcnmFD
SPICcnmFD's Avatar
^Yep. It's only slips in higher gears because it's loaded more than in lower gears.
1993 Rx-7 SM2 #11
At the local AutoX:
Speed for Sale shootout 2007:
A few laps at Barbers:
Old 06-17-2008, 08:34 AM   #4
David Jerome
David Jerome's Avatar
Yep, new clutch disc time.
David Jerome
Old 06-17-2008, 11:25 AM   #5
dinosaur
Member
dinosaur's Avatar
dinosaur is on a distinguished road
I ran mine like this a little too long, had to replace the flywheel too.
93 VR RX7
09 Mini Cooper
75 Cosworth Vega
dinosaur is offline   Reply With Quote
Old 06-17-2008, 01:03 PM   #6
David Jerome
Well anytime you replace a clutch you should go ahead and have the flywheel resurfaced. It is only about $30.00 at any local machine shop.
David Jerome
Old 06-17-2008, 01:14 PM   #7
ok, would NOT doing that cause any problems down the road?
Old 06-17-2008, 02:05 PM   #8
dinosaur
Member
dinosaur's Avatar
I tried to have it resurfaced, after breaking three cutting tools, the shop sent it back. I just got a lightened flywheel and sent the old OEM one to the scrap heap. I had driven to a seasons worth of autocrosses with it slipping, but since it was okay in first and second (autoxing) i kept putting it off.
93 VR RX7
09 Mini Cooper
75 Cosworth Vega
Old 06-18-2008, 01:03 PM   #9
David Jerome
Just excessive wear on the new clutch disc and if the flywheel is really rough it will cause horrible chatter when taking off in first gear or shifting in to 2nd at low rpms.
David Jerome
Old 06-18-2008, 01:13 PM   #10
how about reverse?
Old 06-18-2008, 02:53 PM   #11
David Jerome
how about reverse?
I guess you would probably see the symptom in reverse also, Im pretty sure you would.
David Jerome
Old 06-18-2008, 05:00 PM   #12
AHA! thanks. You indirectly helped me figure out an issue I've been having. I hate it when it's my fault too. Gotta go get the flywheel checked.
Old 06-18-2008, 05:31 PM   #13
David Jerome
Haha, I overlooked this a couple times when I first started working on cars. Sometimes you get lucky but when a flywheel is really rough it will drive you crazy with the chatter.
David Jerome
Old 06-18-2008, 05:43 PM   #14
chatter and random noise. I'll have to get it fixed.
