Go Back   Rotary Car Club > Vendors and Group Buys > All Vendors > BNR Turbos
BNR Turbos www.bnrturbos.com (AL) Custom and rebuilt turbochargers
Old 06-12-2008, 10:16 PM   #1
SleepeR1st
SleepeR1st is on a distinguished road
S4 or S5 uprade?
Hello. I have an 88 T2 with 109k miles on it. Im rebuilding the engine shortly, but i am still contemplating what i would like to do for power modifications. My goal is around 250-300whp on the stock turbo. Now my question is, should i stick with my S4 and send it out to BNR, or should i upgrade to an S5 and then send that out to BNR? I WANT to run the stock turbo, i just have a thing for fast boost
Thanks, Ryan!
SleepeR1st is offline   Reply With Quote
Old 06-13-2008, 12:57 AM   #2
Bryan@BNR
Bryan@BNR is on a distinguished road
S5's win for response. How much boost are you wanting to run to achieve your HP goal?
Bryan@BNR
Bryan@BNR is offline   Reply With Quote
Old 06-13-2008, 05:30 AM   #3
SleepeR1st
10-12
Old 06-13-2008, 12:48 PM   #4
Bryan@BNR
you will be in the 300-320 RWHP range at that boost level with a stage 2. I get 15 psi of boost with my FC on a stage 2 at 3100 RPM in 4th gear. You will be plenty happy with that set up.
Bryan@BNR
205 640 1193
Old 06-14-2008, 10:29 AM   #5
SleepeR1st
Will i be seeing the same power levels from an equivalent stage 2 s4 and s5 turbo? I'll stick with s4 if i am going to hit my goal of over 250whp, saves me some money buy not buying an s5. But my goal also consists of an extremely fast boosting, torquey powerband. Whichever turbo would give me a better result in terms of responsiveness than i might just sway that way.
Old 06-14-2008, 11:38 AM   #6
Bryan@BNR
You can get a little more peak power from a S4 over a S5. The manifold is less restrictive, but the S5 is fully devided and has the best response. If you wanted to stay S4, if you keep your twin scroll and the switching actuator in the exhaust manifold, it will make the S4 turbo more lively down low, but will restrict a bit up top. Either turbo you will enjoy...
Bryan@BNR
Old 06-18-2008, 07:41 PM   #7
rotarycrazy
rotarycrazy's Avatar
rotarycrazy is on a distinguished road
I just got a s5 jdm motor the turbo on it is in awesome shape no shaft paly what so ever exept for the normal. My goal for the car is in the 300whp range it will be used as a spirited driver for the most part so the less lag the better what would you suggest on doing as far as rebuild stage 2 or 3. Also what other mods should I consider to get to my goal.
Thanks Mindaugas
rotarycrazy is offline   Reply With Quote
Old 06-20-2008, 12:03 AM   #8
Bryan@BNR
Thanks Mindaugas
Stage 2 will do 300 RWHP with ease. You will need intake, Full 3" exhaust, chipped ECU, clutch, injectors, pump and a healthy engine .
Bryan@BNR
205 640 1193
Old 07-26-2008, 01:32 PM   #9
rotarycrazy
you have stated a chiped ECU where can I get that done becouse rteck only does S4 turbo and NA S5 also someone told me that S5 ecu will not work by itself that it need to see the remainder of the wiring or it goes into limp mode is that true.
Old 07-28-2008, 10:29 PM   #10
Bryan@BNR
A stock ECU will work good. You will need to pull around 6 degrees out of the timing and then get some 720s with a Super AFC 2 along with a FCD. Then with all the other mods, you should be good for 12-13 psi of boost. I would definatly install an EGT gauge to monitor those exhaust temps, then you will see how much room you have to adjust your timing up or down with the crank angle sensor. Also just as crutial is your AFR's. Make damn sure to keep the engine running pig rich and don't run more than 11.4 AFR at full boost. You may be able to run more boost, but definately keep an eye on that tuning b/c you can ruin the engine in a second if you dont know what you are doing...
Old 07-30-2008, 05:30 AM   #11
Boostmaniac
There was more factual wisdom in this paragraph than you will ever know. I think all TII owners should memorize this before modifying their cars.
