Old 06-11-2008, 02:17 AM   #1
Lotte
~Flippy~
Lotte's Avatar
Lotte is on a distinguished road
99 spec turn lamps
i was wondering if i need a harness for the 99 turn lamps?
Lotte is offline   Reply With Quote
Old 06-11-2008, 08:14 AM   #2
Mobius
Rotorhead
If you're doing a conversion w/ OEM lamps, then yes. AFAIK FDNewbie can get you adapters, and you can get them RHD Japan as well. IIRC the knock off lights don't need an adapter harness.
Old 06-11-2008, 10:42 AM   #3
Brent
Sua Sponte
Brent's Avatar
See this thread: http://www.rotarycarclub.com/showthread.php?t=483
All you have to do to make your bulbs fit on OEM 99spec and the "hyperlite" knock off combo lights is a little filing. You can also get knock off's that come with a plug and play harness. I have had OEM and the knock offs with the harnesses. Never had an issue with either. I'd get the knock off's though, they are cheaper, plug and play, and work and look the same as OEM.
Old 06-13-2008, 02:54 PM   #4
Lotte
~Flippy~
Lotte's Avatar
where can i get the knock offs? can you send a link for it? thanks.
Old 06-18-2008, 02:23 PM   #5
7_rocket
7_rocket's Avatar
7_rocket is on a distinguished road
Ebay
http://www.rotarydynamics.ca
7_rocket is offline   Reply With Quote
